Dido Posted September 3, 2010 Share Posted September 3, 2010 Hello, Can someone please tell me how to define material of any created objects in Solidworks 2008? Thanks in advance Dido Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 3, 2010 Share Posted September 3, 2010 Near the top of your browser you should see Materials. What happens if you right click on that? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted September 3, 2010 Share Posted September 3, 2010 Are you wishing to define the material of the object(ie aluminum) or change the appearance of the object(ie powder coat). If you are trying to change your material there are a few ways to get to it. One way is to right click on the name of your part at the top of the Feature Tree. In the pop up window go down to Appearance>Edit Material. Also in your feature tree you should have a Material heading under the Solid Bodies folder just above your standard planes. If you right click on that you can apply some of the standard materials or go to the Edit Materials window from there. Quote Link to comment Share on other sites More sharing options...
