Results 1 to 4 of 4
    Senior Member
    vertical horizons's Computer Details
    Windows 8 PRO
    DX79TO
    I-7 3820 @3.60 GHz
    16.0 GB
    AMD FirePro W7000
    16 GB
    ViewSonic VX2739wm (Primary) & HP w1907 (Secondary)
    Manufacture
    vertical horizons's Discipline Details
    Drafting Supervisor
    Manufacture
    not applicable
    Mar 2010
    Texas
    237
    Default 2D Sketch VS 3D Sketch
    While in sketch mode, there is a tab that allows you to select either 2D Sketch or 3D Sketch.
    I have always sketched in 2D mode, then followed up with extrude, revolve, etc.,. Under what conditions would someone sketch in 3D mode, rather than 2D?
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    679
    Piping or Cable and harness design springs to mnd...
    Junior Member
    MrJoshua's Computer Details
    Windows 7 X64
    Inventor 2011
    Jun 2009
    17
    I use it to make skeleton wire frames , then use the frame generator to finish the model.
    I also use it on handrails, draw all the posts then place a work point on the top of the posts then join the dots with a 3D sketch, followed by a sweep
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    3,249
    It is much easier to control a 2d sketch. With inventor I typically only use 3d sketches either for harness data, or to project 2d sketches to get a 3d intersection curve.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks17,Mastercam2017, fusion360, Inventor 2017, HSMworksUltimate
    http://www.solidbox.tv Free and Paid Tutorials for Solidworks, Mastercam and Fusion360
    http://www.mysolidbox.com/ CAD and CAM optimized workstations and laptops
  1. Need Help With 3D Sketch
    By Uncle Harley in forum Autodesk Inventor
    Last Post: 27th Aug 2009, 12:57 am
  2. inventor sketch to autocad sketch posible?
    By matulja87 in forum Autodesk Inventor
    Last Post: 11th Aug 2009, 03:11 pm
  3. 3d Sketch to XYZ
    By Lazer in forum Autodesk Inventor
    Last Post: 26th Aug 2007, 01:59 pm
  4. first sketch
    By JBullseye74 in forum SketchUp
    Last Post: 12th Apr 2006, 12:03 am
