printing to PDF - AutoCad 2009 issues
Coggz
The preview (and subsequent print) always shows portrait page layout - and whichever portrait or landscape selected the layout shows and prints as landscape but across the portrait page width.
Sounds like the problem is in your plot configuration's PMP file.
You can check this (*IF* you have write access to your PMPs) by going into your named page setup...
  • Page Setup Manager > Select your page setup > Modify button
Then next to the printer name, select the properties button.
Under the "Modify Standard Paper Sizes (Printable Area) node, select your paper size in the displayed "Modify Standard Paper Sizes window... click the modify button.
Hope this helps!
