Results 1 to 7 of 7
    Senior Member ziemerd's Avatar
    ziemerd's Computer Details
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    Default Can't Rotate Image
    I have a picture of a controller in a drawing that I need to rotate but ACAD won't rotate it. I've been able to rotate other objects so I know how it works but this image won't rotate.
    Any ideas?
    Thank you.
    Dawn
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,947
    Dawn,
    In order for me to try to replicate this situation...
    What type of image is it (i.e., OLE, Raster, etc.), and what method did you use to insert the image into your drawing (i.e., mapinsert, xref, etc.)?
    Could you post the image (the drawing also)?
    "Potential has a shelf life." - Margaret Atwood
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    I believe it is an OLE and I just copied and pasted the image into the drawing. Unfortunately I can't get the image small enough to upload to the forum. It exceeds the limit.
    Civil 3D 2011
    Nov 2009
    3,947
    No worries.
    Instead of copy + paste (= OLE), you should insert the image. Even if the ._mapinsert command is unavailable to you, I believe you *should* be able to simple drag the image from windows explorer into your AutoCAD session (some scale or adjustment may be necessary).
    These are the methods I used prior to my post.
    Good luck!
  5. #5
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    Thanks RenderMan. I'll try it and see if it will work for me.
  6. #6
    XP
    HP
    Architecture 2011
    Sep 2004
    Waterloo, IA
    413
    I got it to work by using Paste Special and pasting it as Image Entity. Thanks again.
  7. #7
    Civil 3D 2011
    Nov 2009
    3,947
    You're welcome.
  1. Rotate (& un-rotate) UCS
    By Mr.Alex in forum AutoCAD General
    Last Post: 16th Apr 2009, 05:43 pm
  2. Image Manager & Image Profiles Etc.
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 2nd Apr 2009, 03:51 am
  3. Move/Rotate Copy/Rotate lsp
    By hiddenline in forum AutoCAD Beginners' Area
    Last Post: 19th Mar 2009, 11:12 pm
  4. Rotate
    By bbankston in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2008, 05:24 pm
  5. Can't rotate in 3D?!?!
    By johnny1 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Apr 2008, 04:46 pm
