Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    not specified
    Dec 2005
    4
    Default How do I make dim lines invisible to end point snap?
    If I'm not careful the end point snap will pick up a dim/ext line and not the part drawing line when putting in dimensions.
    I've dug around in the settings to try and find something with no luck.
    I don't CAD for a direct living but use it as an aid as a machinist.
    Using both R14 and 2002
    TIA
    Bill
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    Not to sure i get the question
    Have you set up layers and added the dims to the dim layer so you can turn them on and off as you please?
    or maybe
    Try changing the SELECTION and DRAFTING options
    OPTIONS>SELECTION TAB and change the pick box to a larger size
    Tip use the zoom to select or when adding dims.
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
    Forum Newbie
    not specified
    Dec 2005
    4
    Quote Originally Posted by deelay
    or maybe
    Well my main problem is that I don't zoom in enough and pick up a dim line and not a part line when adding dims. I have been getting better with layers and have a layer named as DIMS. But I still need it on as I'm still adding dimensions.
    I would just like to find a way that I can not snap to any part of the dimension. Is there a layer or line setting I could use for dims so they can't be snapped on?
    I know that a drafting software that our CNC programers use will not allow this to happen.
    I hope that clears it up alittle more.
    Bill
    Windows 7
    8GB
    1TB
    Portable TB drive
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    If the main problem is you cannot zoom in enough the the answer is to regen with it stops zooming in ..
    zoom in till it stops and type regen in the command line. then you should be able to zoom in even more.
    Hope this helps
  5. #5
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Try to change your dimstyle so that the dimline ends right on the end of the dimensioned line.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  6. #6
    Windows 7
    8GB
    1TB
    Portable TB drive
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    nice idea fuccaro
    and on that it gave me another idea , you could change your DimStyle settings (format>dimension style>modify>lines and arrows tab click extension lines to say RED then u cannot go wrong,
    i hope.
  7. #7
    Super Member ASMI's Avatar
    AutoCAD 2008
    Nov 2005
    Oceanus Procellarum, Moon
    1,427
    Try AlxdOSnapFilter v1.0 http://www.alx.ncn.ru/body.php?lang=en&part=download It's for free.
  8. #8
    Forum Newbie
    not specified
    Dec 2005
    4
    Quote Originally Posted by ASMI
    Hey Thanks. That sounds just like what I'm looking for.
    "This software can filter entities under cursor to calculate osnap point. In other words, can exclude entities from osnap. "
    Thats extactly what I was trying to say
  9. #9
    Senior Member
    not specified
    Mar 2005
    204
    This is one of the things I love about Autocad Mechanical...osnaps don't detect dims by default...although it can be changed.
    It's just one little thing, but when my Mechanical wasn't working for a while (I had to use plain Autocad)...this drove me crazy on a daily basis.
    If there is anything the nonconformist hates worse than a conformist,
    it's another nonconformist who doesn't conform
    to the prevailing standard of nonconformity.
  10. #10
    Forum Newbie
    not specified
    Dec 2005
    4
    Well I got the alxdosnapfilter loaded and running but I can't seem to get it to work.
    All the commands are going in and the mode is on (trying to filter "dims" name layer) but its not working. The read me file is not much help.
    Anyway now that I've been pointed in the right direction I've been able to search and find Flatland http://www.caddzone.com/acadxtabs/flatland.htm
    Which is up and running ok.
    Thanks
    Bill[/code]
