Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    AutoCAD 2007
    Sep 2010
    13
    Default DWG to PDF printing problems
    Hi!
    Can someone please help me with the ploting problem? Couse when I plot my AutoCad drawings to PDF format places where are solid hatch it gets striped, brushed and so what ever... I have tried every thing I know starting with various PDF printers, tried to change some sttings in AutoCad plot sections no use! Im getting a little bit mad of this s**t.
    Maby there is some ploting setings or something?!
    What can I do is there someone that could help me plssssss.
    Thanks a LOT!
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Congrats on your first post, and welcome to the forums!
    What I have had to do prior to using 2009 applications, is a simple two step process.
    • Publish to DWF (Step # 1) > Print the DWF to PDF (Step # 2)
    More specifically, the way I've done this in the past (this isn't the only way), is to create a named page setup which prints my plan sheets to DWF correctly. My DWFePlot driver shifts the page to the right, so even if it looks good in the plot preview, check the resulting DWF file!
    Save this page setup to the cover sheet in my plan set.
    Then in the publish window, add your drawings, and for sheets other than your cover sheet (where the page setup is saved), import said page setup from the cover sheet.
    Check the button for printing to DWF, and publish.
    Hope this helps!
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    I use DWG TRUEVIEW 2010 downloaded free from the AutoDesk website to plot to pdf format. Merely open the drawing in trueview and print just as if it were AutoCAD. It solved all of my print quality issues I have with AutoCAD LT 2009 and my issues were the same as yours. Fonts printing fuzzy or not at all, hatches messed up, and random line weight changes all solved.
    Another side benefit is that the resulting pdf is almost 80% smaller in file size than the AutoCAD output, even though the layer names and on/off controls are still there in the pdf. If you use a lot of blocks and xrefs, you may be asked to try and resolve "Unresolved External References" or ignore them. I usually have no issues ignoring them.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Yeah, we use TrueView 2010 also, but not for this task.
    In lieu of the AutoCAD PDF driver provided with C3D LDC 2009, we actually had much better quality using the driver that came with DeskPDF. One shot-go... simply publish to PDF. Great quality, small package.
  5. #5
    Junior Member
    AutoCAD 2007
    Sep 2010
    13
    thanx comrads! I'l try out your suggestion.
  6. #6
    Junior Member
    AutoCAD 2007
    Sep 2010
    13
    THANX!!!!! working smooooooooooooooooooooth!!!!!!!!!
  7. #7
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    You're welcome.
  8. #8
    Junior Member
    AutoCAD 2007
    Sep 2010
    13
    Quote Originally Posted by RenderMan View Post
    Could you please send me that Autocad driver that you were talking about?! rogis3@inbox.lv
    thanx
    I tried the DWG truewiev it was ok, but now I have Windows 7 and the truewiev doesnt work...
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by aigars007 View Post
    thanx
    Go back and download TrueView 2011. It is Win 7 compatible. In 20 minutes you'll be running again.
  10. #10
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by Dana W View Post
    We're in the process of migrating all active projects to new servers, and will be getting all new PC's with Windows 7 on them... I had requested TrueView 2010 be installed, but if I now need 2011, I need to inform Management, and IT ASAP.
    Thanks for the information, Dana.
  1. Problems printing to PDF
    By AaronisDaBonis in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Jun 2010, 08:31 am
  2. Printing problems
    By NTX JK in forum AutoCAD Drawing Management & Output
    Last Post: 10th Feb 2010, 09:43 pm
  3. Printing problems
    By SREMO in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Dec 2009, 06:23 pm
  4. Problems with printing
    By Susan B in forum AutoCAD Beginners' Area
    Last Post: 24th Jul 2008, 01:43 pm
