Grah Posted September 10, 2010 Share Posted September 10, 2010 I have a user who has just started to have this problem When autosave kicks in (every 5 mins for him) the drawing will zoom and pan to a different spot in model space for a second or 2 then back to where he was working, this is obviously very annoying for him but were at a loss as to whats causing it. Rough specs but this issue is new so I dont think its the system Win xp Acad 2010 Intel core duo 2.66 4g ram Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 10, 2010 Share Posted September 10, 2010 Congrats on your first post, and welcome to the forums! First some questions to consider: Does this only happen in one specific drawing? Does this happen to other users in the same drawing(s) that you've identified the problem? Does this continue after restarting AutoCAD (and/or the PC)? Aside from a reactor (perhaps an editor, or command reactor specifically), I do not know what could cause this to happen. It would make for a *funny* (albeit unproductive) prank on a 'New guy'. To test this theory, please open the problem drawing, and enter this code into the command line: (vlr-remove-all) ...Does this *issue* continue to occur? If so, then my theory is incorrect. If not, then someone has a reactor loading, possibly with ACADDOC.lsp. Good luck! Quote Link to comment Share on other sites More sharing options...
