Results 1 to 3 of 3
    Forum Newbie
    not specified
    Dec 2005
    1
    Default Slicing 3d models
    I am new to Autocad but I have a 3d autocad model that I wish to slice into sections 10cm apart so I can then print them out in 2d sections. Is there an easy way to do this?
    Full Member
    not specified
    Nov 2005
    48
    If the 3d model is 3d solid, you can use the command call SECTION. It will automatically highlight section cut within a plane. If the 3d model is combination of 3d solid and 3d mesh, you need program like ADT to perform section cut.
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,640
    Quote Originally Posted by scourdx
    SECTION is non-destructive and creates a region.
    You can SLICE a solid model,it is then split. In Acad.
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
