Results 1 to 9 of 9
    Senior Member
    not specified
    Mar 2005
    204
    Default Pick list for attribute?
    Is it possible to create a list to pick from, as an option for an attribute? (or maybe a good work around for what I'm trying to do?)
    I'm creating a new title block (block) and for some of the attributes, the required value will usually be one of two or three options. A simplified example would be color...it will either be Red, Blue or Green. So rather than just having Red as the preset attribute value..and having to type blue or green when needed, I want to be able to pick one from a list. (or something like that).
    I've been trying to see if a Field would work. I can add 'Red, Blue & Green' as comments or keywords in the drawing properties, and then use that to create a Field...but it just adds them all.
    I thought maybe I could create a table with the different values, but I can't find a way to create a Field from a table, and even if I could, I'm not sure it would work how I want.
    I could also add all three values as the preset for the attribute, then just delete the ones I don't want...but I'd prefer a more refined solution, if there is one.
    Can anyone point me the right direction?
    If there is anything the nonconformist hates worse than a conformist,
    it's another nonconformist who doesn't conform
    to the prevailing standard of nonconformity.
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,945
    Just curious...
    Is/are there any specific criteria that would prompt your desire to change the attribute color (Plotting/CTB related), or is this purely an aesthetic function?
    I could be wrong, but *IF* memory serves... a ._refedit alone will not change the color of the attributes (once the attribute has been given a value). One would have to ._refedit, insert a new instance of the desired block, and then translate the original values to the new attributes.
    "Potential has a shelf life." - Margaret Atwood
    Senior Member
    not specified
    Mar 2005
    204
    The color was just an example. The values that I'm using are fabric specifications, "PE 12oz. F.R. WH/WH (RU88X-6FR)" for example. This is why I want to pick from a list, rather than having to type it out, or find it somewhere to copy/paste.
    Civil 3D 2011
    Nov 2009
    3,945
    Well attribute color, and attribute value (textstring property) are two completely different beasts! Why didn't you say so in the first place, my friend!?
    If there is a specific bit of criteria (file name prefix, etc.) that in any way indicates which fabric would be needed, we can do this programmatically, with fields.
    If not, then LISP can do the job handily, it's just more work... The pick list might just be a simple initget + getkword combo. But, it sounds like we need some additional criteria though, like title block name (effectivename property), attribute tag strings, and others, etc.
  5. #5
    Senior Member
    not specified
    Mar 2005
    204
    I appreciate your help.
    No, there is no specific criteria (associated with the drawing file) that would determine the fabric type...we just read it off of the work order and enter it into the drawing's title block.
    It's been many years since I last dug into LISP programing, and I didn't dig too deeply. I figured that was the direction I might have to go...so I've been walking though an AutoLISP tutorial for the last half hour...but I'm still at the very basics.
  6. #6
    Civil 3D 2011
    Nov 2009
    3,945
    You're welcome.
    No worries about the criteria, again presenting you with the options for fabric selection is the easy part. When you begin to dig into the title block attributes (and not that it's difficult), is where Visual LISP makes things real efficient.
    I'm subscribed to this thread, so feel free to post back what you've put together, and I (or someone smarter!) will happy to help you out.
    Good luck!
  7. #7
    Forum Newbie
    AutoCAD 2008
    Sep 2010
    1
    why not use a dynamic block with a visabilty parameter?
  8. #8
    Senior Member
    not specified
    Mar 2005
    204
    Thanks, I'll look into that.
    I'm actually getting into Sheet Sets for the first time, and while it doesn't appear to solve this particular issue, I think it will make a better workflow for me. And I might be able to hide the fabric spec. I need, in the sheet properties somewhere.
  9. #9
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Hey go old school !
    You can pop side menu open and these can contain preset answers eg 1 2 3 4 5 etc or part numbers, you would need to create them but are pretty simple as they are a menu file. I used this method for brick widths ie pick 1 brick but answer is 237. Here is an example for sheet sizes
    Code:
    **SET_SH 2
    [  SHEET ]
    [  SIZE: ]
    [   A0   ]0
    [   A1   ]1
    [   A2   ]2
    [   A3   ]3
    [ A4 L'SC]4
    [ A4 PORT]41
    [   B1   ]5
    [   B2   ]6
    [  USER  ]90
    [  NONE  ]99
    The number on the right is what is returned, you can definately return the pick menu as an answer to a lisp question rather than keyboard.
    I haven't used for a while but its probably worthwhile a try. You can also join answers (use lisp) if you have a complicated part No red+velvet+straight 3 picks.
    The other alternative is to just open a text file and populate a dcl list box, the advantage of the txt file is you can change answers without changing any program code.
    Alanjt has a real nice version of a list box routine maybe ask him nicely to add open file to it. I would do it but its his to give away.
    Your lisp would be pretty simple open file/s get answer/s then block command
  1. Attribute value with drop down list for 2008 LT???
    By BrentonJohn316 in forum AutoCAD General
    Last Post: 11th Feb 2010, 03:53 pm
  2. write a list into text file and return back as list
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Dec 2009, 04:31 pm
  3. Pick out the common in a list
    By devitg in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Nov 2009, 03:09 am
  4. "User defined attribute list" won't save settings
    By M_Simons in forum Electrical
    Last Post: 17th Aug 2009, 04:15 pm
  5. Attribute value with drop down list?
    By Guite in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Mar 2008, 12:40 pm
