babati Posted September 20, 2010 Share Posted September 20, 2010 Hello all, I am new . Since i even don't know in which category my problem is, I apologise if it is mentioned in other threads. I use Autocad 2011 and I draw in millimetres. When I draw a line 3000 mm it does not fit in my drawing space (it says it is fully zoomed out before i see both end of the line). In my previous educational Autocad 2011 in the drawing coordinates window (down left corner) shows much bigger numbers for shorter line(if this can help). Is the drawing space too 'small'? Something to do with WCS/UCS? Any help will be much appreciated! Quote Link to comment Share on other sites More sharing options...
nukecad Posted September 20, 2010 Share Posted September 20, 2010 Its just a function of how big your window is zoomed to. You say you are "Fully zoomed out" but will find that you can zoom out further so that the line will LOOK smaller on your screen even though its the same length. Try typing- z e (Zoom Extents, fits your drawing to the screen) Then- z .1 (Zoom out to 1/10 of current window - drawing will LOOK smaller on the screen) Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 20, 2010 Share Posted September 20, 2010 Set Limits Off RE Enter Zoom all Quote Link to comment Share on other sites More sharing options...
babati Posted September 20, 2010 Author Share Posted September 20, 2010 Thank you both for the quick and successful fixes!!! Quote Link to comment Share on other sites More sharing options...
rkent Posted September 20, 2010 Share Posted September 20, 2010 Set Limits OffRE Enter Zoom all or just double click the intelliwheel (for zoom extents) Quote Link to comment Share on other sites More sharing options...
rvpas Posted September 20, 2010 Share Posted September 20, 2010 Hi babati To complete this post. The next time, you can change the limits of your drawing By default left low corner 0,0 and high right corner 420,297 units Type limits in your command line (its old command) and change the value Later if you want, you can use save as DWT your drawing (template) for a later. use To extend to the drawing limits use zoom all By Pascal Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 21, 2010 Share Posted September 21, 2010 As per rvpas but if your going to set your limits for zoom all then you need to set them to be bigger than your object, not your paper size, for a house say 0,0 20000,20000. We tend to use z e zoom extent rather than set limits, as you found if you draw a long line zoom e then just roll the mouse button a bit and it should zoom a bit more even draw a box as a first step 0,0 20,000,20,000 this way you know you will always be inside. if you want to know as you are going if it will fit on your sheet when plotted you just need to draw a box that reflects the size of your plot sheet and then scale it up by the plotted scale. Still use layout tabs and title blocks for the final plot. Quote Link to comment Share on other sites More sharing options...
babati Posted September 21, 2010 Author Share Posted September 21, 2010 Thank you so much for your advises! I now understand it is a very basic step I've missed - to zoom correctly. Quote Link to comment Share on other sites More sharing options...
