Are the units set to the same in both drawings?
Hello,
I have the problem that when i copy a layout through designcenter to a other drawing everything scales in the new layout.
The text in the titleblock gets very big, some revision and concept stamps getting diverent sizes. And the printarea doesen't fit the drawingframe anymore.
I was thinking of problems with the scalefactor of the block, but they are all 1 in the source and target drawing.
What do i wrong? This is happening in different drawings
I'm using acad 2009 LT.
Allready thanks for the help.
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Yes, they are the same. It's the same range of drawings from one building.
What values are all the following set to in each drawing:
InsUnits, InsUnitsDefSource and InsUnitsDefTargets
Life's constantly changing - keep up or get left behind
InsUnits = 4
InsUnitsDefSource = 4
InsUnitsDefTarget = 4
Can it be a problem that the units of some block's (titleblock and the stamps) are set on "unitless" and the drawing is in mm's?
I try further.
edit: 1:35 pm
Between the original titleblock and the copied one is a scalefactor of 25,4. Looks like a inch and mm problem, but between the text hight of the attributes in the same block is a scalefactor of 644.
I have also started two new drawings, edited the blockunit to mm and copied the layout again, but with the same result.
I found the answer.
Using the command -DWGUNITS solve the problem.
These are the settings i use:
Command: -dwgunits
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length <4>: 6
Drawing unit display formats:
1. Scientific
2. Decimal
Linear display format <2>:
Linear display precision <4>:
Scale objects from other drawings upon insert? [Yes/No] <Yes>: n
Match INSUNITS to drawing units? [Yes/No] <Yes>: n
** WARNING: you have changed the unit for this drawing database. **
** All new objects will be drawn according to the new unit, but **
** existing objects will not change size unless you specifically **
** ask to have automatic scaling occur. **
Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>: n
