Results 1 to 4 of 4
    Full Member
    Mechanical
    AutoCAD 2012
    Nov 2009
    27
    Unhappy Help) How can I bend a 3d
    Can some one please help. How can I make a bar of metal 50mmx50mm by 2.5m bend over 100mm, 1/2 way up the bar. I'm doing this in 3d. Thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Something like this? I did not use your dimensions.
    Done using the SWEEP command. The "path" (single line) was drawn with the UCS reoriented.
    Users of older versions of AutoCAD (ex. - 2000) do not have the SWEEP command. Use the EXTRUDE command instead. Placement of the object to be swept is critical. Your results may vary.
    Full Member
    Mechanical
    AutoCAD 2012
    Nov 2009
    27
    Default Thanks
    thanks for that.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    You're welcomed Mr guiff.
  1. Bend vs Fold
    By farrous13 in forum Autodesk Inventor
    Last Post: 17th Dec 2010, 05:29 pm
  2. How to bend it...
    By nikhil in forum Autodesk Inventor
    Last Post: 25th Aug 2010, 09:36 am
  3. Bend Tables
    By robertf in forum Autodesk Inventor
    Last Post: 9th Mar 2009, 11:39 pm
  4. How do I bend a rectangle?
    By jlovgren in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Jan 2009, 06:49 pm
  5. Adding Bend
    By tuxarut in forum SolidWorks
    Last Post: 10th Nov 2008, 08:24 pm
