Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2007
    Sep 2010
    2
    Default Annotation- Drawing Title-Metric
    When you insert the drawing title it always post a scale of 1 to 1 is there a way to have this automatically adjust to whatever view port you put it in??
    Forum Newbie
    AutoCAD 2007
    Sep 2010
    2
    ok so when you drag the "drawing title-metric" block from the annotation tab of your toolbar pallet is there a way to have it automatically fill in the correct scale or is this something you must do manually each time.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,020
    If you are inserting the title block into a layout then the default of 1:1 will always be correct. After all, your viewports can be assigned any scale but when you print you do so from your layout at a scale of 1:1.
  1. Drawing Annotation
    By BobCast0865 in forum Autodesk Inventor
    Last Post: 13th Jun 2010, 05:07 pm
  2. Drawing in metric.
    By EMS_0525 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Nov 2008, 03:00 pm
  3. convert drawing in inches to metric?
    By scubadoo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Apr 2008, 04:28 pm
  4. Drawing annotation problems - Inv 10
    By sludd in forum Autodesk Inventor
    Last Post: 13th Sep 2007, 08:35 am
  5. Metric Drawing Help
    By wastewater in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jan 2007, 04:04 pm
