Guest kruuger Posted September 25, 2010 Share Posted September 25, 2010 (edited) Hello Everyone, I just want to share small lisp routine. Maybe someone find it usefull. Any comments and suggestions are welcome. kruuger V1.03 Spiderdim.lsp Spiderdim.dcl Edited October 22, 2010 by kruuger Quote Link to comment Share on other sites More sharing options...
blueshake Posted September 25, 2010 Share Posted September 25, 2010 thank you for your share.from the show,it seems it is used find matched texts in dimension.?? Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted September 26, 2010 Share Posted September 26, 2010 thank you for your share.from the show,it seems it is used find matched texts in dimension.?? yes, lisp go thru dims and mark them with lines (spider). it is much better then selection set from autocad find command and not disappear after screen regeneration. kruuger Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 26, 2010 Share Posted September 26, 2010 Just curious... Why not change the color of a selection set of dims instead (no spider)? (vla-put-color <object> <color>) Then your 'marked' selection is not lost after a regen. Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted September 26, 2010 Share Posted September 26, 2010 Just curious... Why not change the color of a selection set of dims instead (no spider)? (vla-put-color <object> <color>) Then your 'marked' selection is not lost after a regen. Personally i do not prefer any modification to drawing (like making additional layers, changing object properties until it is really necessary). I agree that put-color will be faster but i also want play with grread. I'm still rookie with this. Thanks for interesting kruuger Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 26, 2010 Share Posted September 26, 2010 A very great work kruuger. Wish you best of luck. Tharwat Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted September 26, 2010 Share Posted September 26, 2010 A very great work kruuger. Wish you best of luck. Tharwat Thanks tharwat113. I wish to add nested dimension or xref. But for now looks like it is beyond my lisp knowledge. kruuger Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 26, 2010 Share Posted September 26, 2010 What if the text is within the Prefix/Suffix (set in style) instead of TextOverride? Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted September 26, 2010 Share Posted September 26, 2010 What if the text is within the Prefix/Suffix (set in style) instead of TextOverride? aaa good catch Alan. I don't even think about this (my brain is to small). i see what i can do with this. thanks kruuger Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted September 27, 2010 Share Posted September 27, 2010 Bardzo ladnie Ci to wyszlo. Very nice done. Thank you. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 27, 2010 Share Posted September 27, 2010 Personally i do not prefer any modification to drawing (like making additional layers, changing object properties until it is really necessary).I agree that put-color will be faster but i also want play with grread. I'm still rookie with this. No worries. Please do not misunderstand me, I have *some* proficiency using LISP, but I am a complete novice with DCL (I've never tried it!). You have done a great job in that regard. Good luck! Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted September 27, 2010 Share Posted September 27, 2010 Bardzo ladnie Ci to wyszlo.Very nice done. Thank you. Haha, Dzieki Thanks No worries. Please do not misunderstand me, I have *some* proficiency using LISP, but I am a complete novice with DCL (I've never tried it!). You have done a great job in that regard. Good luck! Of course not So I learn a lot from your LISP code many times. Any help with DCL just ask. progress.... Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 27, 2010 Share Posted September 27, 2010 Of course not So I learn a lot from your LISP code many times. Any help with DCL just ask. Thanks, that is very kind of you. Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 28, 2010 Share Posted September 28, 2010 kruuger, I hope you don't mind and I haven't stepped on your toes (if I have I apologize and will promptly remove my snippet), but I was killing time over the weekend and thought I'd scratch this out as a very simple demo... (defun c:DimSearch (/ flt lst n gr) ;; Alan J. Thompson, 09.27.10 (vl-load-com) (if (and (/= "" (setq flt (strcase (getstring T "\nSpecify search filter: ")))) (princ "\nSelect dimensions to search <All>: ") ((lambda (ss / dims ss) (if (setq dims (cond ((ssget '((0 . "DIMENSION")))) ((ssget "_X" '((0 . "DIMENSION")))) ) ) (progn (vlax-for x (setq dims (vla-get-activeselectionset (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object) ) ) ) ) ) ) (if (vl-member-if (function (lambda (s) (wcmatch s flt))) (mapcar (function (lambda (p) (strcase (vlax-get-property x p)))) '(TextOverride TextPrefix TextSuffix) ) ) (setq lst (cons (trans (vlax-get x 'TextPosition) 0 1) lst) ss (ssadd (vlax-vla-object->ename x) ss) ) ) ) (vla-delete dims) (sssetfirst nil ss) (ssget "_I") ) ) ) (ssadd) ) (setq n -1) ) (while (and (eq 5 (car (setq gr (grread T 15 0)))) (vl-consp (cadr gr))) (redraw) (foreach p lst (grdraw (cadr gr) p 1)) ) ) (redraw) (princ) ) Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted September 28, 2010 Share Posted September 28, 2010 kruuger,I hope you don't mind and I haven't stepped on your toes (if I have I apologize and will promptly remove my snippet), but I was killing time over the weekend and thought I'd scratch this out as a very simple demo... You guys making crazy stuff here. I always want to see another solution. There is lot to learn from your code. Maybe i can "steal" some line from your code :wink:kruuger Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 28, 2010 Share Posted September 28, 2010 You guys making crazy stuff here. I always want to see another solution. There is lot to learn from your code. Maybe i can "steal" some line from your code :wink:kruuger Go for it; that's why I posted. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 28, 2010 Share Posted September 28, 2010 Go for it; that's why I posted. Isn't it wonderful...? The leaves are changing... winter will be here before you know it... and Alan (this whole time) is sharing his Christmas spirit (and code) with others. Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted October 22, 2010 Share Posted October 22, 2010 updated code in first post v1.03 kruuger Quote Link to comment Share on other sites More sharing options...
catoscuro Posted May 29, 2015 Share Posted May 29, 2015 please update to autocad2015, thanks Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted June 1, 2015 Share Posted June 1, 2015 please update to autocad2015, thanks any errors ? try (vl-load-com) first and than spider. kruuger Quote Link to comment Share on other sites More sharing options...
