zidanelam Posted October 3, 2010 Share Posted October 3, 2010 Hello, Can I know how can i do rope and pulley simulation? I would like to use a rope to lift up a crane. I have tried Belt and Chain, but the belt is in closed loop. I have drawn out the blocks of the pulley, crane and all the mechanism, now i would like to link them with a rope Please guide me how to do this simulation in 2D as well as 3D Thanks in advance Quote Link to comment Share on other sites More sharing options...
shift1313 Posted October 4, 2010 Share Posted October 4, 2010 Having an object moved in that manner isnt too difficult but actually showing the rope change is a bit more complex of a problem. Do you simply need something to raise or do you actually need the rope to look as though its moving? How far are we talking about? Quote Link to comment Share on other sites More sharing options...
zidanelam Posted October 4, 2010 Author Share Posted October 4, 2010 I want to make the rope move, in pulley manners. Meaning to say that, if i pulled the string, it will increase the length of rope in my side and decrease the length of rope on the other side of pulley. I can make the object move, by adding relation. But I can't relate it with the string. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted October 4, 2010 Share Posted October 4, 2010 What version of SW are you using? Off the top of my head im thinking you will need to have an equation setup for your rope length. You can make things "flexible" and adaptive in a sense but pulling the rope will be tough. Let me give it some thought and see if i can come up with a good way to do this for you today. If you are using 2009 or newer i will be able to upload a file for you to see. If you are using 08 or older you will not be able to open any file I create. Quote Link to comment Share on other sites More sharing options...
zidanelam Posted October 4, 2010 Author Share Posted October 4, 2010 I'm using SW 2010, should be no problem. Thanks for your help Quote Link to comment Share on other sites More sharing options...
shift1313 Posted October 5, 2010 Share Posted October 5, 2010 I have tried something with no luck. Do you really need to "pull" the rope or can it be animated with the rope/box moving around the pulley? The dynamic pull on the rope is the issue. There is a work around( i think) by making two ropes. The end of one rope in the assembly will have the other based off it but i still dont know if this will work. Let me know what your end goal is and I will see what I can do. Quote Link to comment Share on other sites More sharing options...
bhamze Posted October 5, 2010 Share Posted October 5, 2010 I think this can be accomplished by utilizing in context modeling. Basically, I'm thinking of using a hidden object to drive the rope. I've used this technique in the past to animate a speaker gasket. I will give it a try later, I'm very busy though. Quote Link to comment Share on other sites More sharing options...
zidanelam Posted October 6, 2010 Author Share Posted October 6, 2010 Thanks for your efforts, I think it's not very important to do the simulation. What I'm doing now is building a robot with pulley attached to it. Basically, I would like to do simulation first before coming out the real prototype. Anyway, I really appreciate of what you have did, I know it's not an easy task. Don't worry, this is not really important Quote Link to comment Share on other sites More sharing options...
zidanelam Posted October 6, 2010 Author Share Posted October 6, 2010 Or you can recommend me any modeling software that can do this simulation easily. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted October 6, 2010 Share Posted October 6, 2010 Well you can easily do a motion simulation that doesnt involve the rope, rather a force on the pulley. Can you maybe post a screen shot of what you are working with and some notes on the sort of motion you want. Quote Link to comment Share on other sites More sharing options...
bhamze Posted October 6, 2010 Share Posted October 6, 2010 Here's a quick animation I created in SW2010. If you want the SW files, let me know. Is this similar to what you want to accomplish? http://www.youtube.com/watch?v=rotKs_bgoZA Quote Link to comment Share on other sites More sharing options...
shift1313 Posted October 7, 2010 Share Posted October 7, 2010 That looks great bill! Quote Link to comment Share on other sites More sharing options...
bhamze Posted October 7, 2010 Share Posted October 7, 2010 Thanks Matt Quote Link to comment Share on other sites More sharing options...
zidanelam Posted October 7, 2010 Author Share Posted October 7, 2010 bhamaze, Yes!! this is what i need. Can you send me the SW file? Thank you very much Quote Link to comment Share on other sites More sharing options...
bhamze Posted October 7, 2010 Share Posted October 7, 2010 Here you go. Pay close attention to the equations in both the part and assembly files. Also take note of the relations between the different parts. This may look basic but as Matt said....... it very complex. If you're having trouble, let me know. I'll try my best to help. You need to download both files, this post will contain the assembly followed by the part files. Pulley.zip Quote Link to comment Share on other sites More sharing options...
bhamze Posted October 7, 2010 Share Posted October 7, 2010 Second set of files Pulley2.zip Quote Link to comment Share on other sites More sharing options...
dick_timmerman Posted October 27, 2010 Share Posted October 27, 2010 Maybe this link can be of help: http://www.youtube.com/watch?v=j3Y7CeeN83U&feature=related Quote Link to comment Share on other sites More sharing options...
ntweisen Posted November 17, 2010 Share Posted November 17, 2010 I have an assembly which is essentially a pulley and a counterweight. Everytime I move the counter weight up or down the connecting cables do not stay attached. I have to rebuild/update in order for them reconnect to their proper positions. Is there any way I can keep all the parts attached and connected together without having to update/refresh/rebuild the part? Quote Link to comment Share on other sites More sharing options...
bhamze Posted November 18, 2010 Share Posted November 18, 2010 Do you have a mate that drives the counter weight? If you change the mate value the assembly should automatically rebuild. If your dragging the weight I think the only option is to manually rebuild assembly. Quote Link to comment Share on other sites More sharing options...
