Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    AutoCAD 2010
    Aug 2010
    44
    Default I can't get my TEXT to take
    I am trying to enter the names of rooms on a floorplan I am working on. I type in text or dtext on the command line. Then I select where the text is to go. The height is already set, so I press enter. The rotation angle is 0 so I press enter again.
    I type in my text and then hit enter twice. When I hit enter the second time the text disappears. I have done this before with no problem. Why am I having a problem today?
    Super Member nukecad's Avatar
    nukecad's Computer Details
    XP64
    Various machines.
    AutoCAD LT 2006
    Apr 2009
    NW Cumbria (English Lake District)
    500
    Are you putting it onto a layer that is turned off or invisible?
    *** Out of Beer Error ->-> Recovering Memory***
    Full Member
    AutoCAD 2010
    Aug 2010
    44
    Unhappy
    I tried printing on the object layer where I had all of the walls drawn, so they were obviously visible, but I still can't get my text to appear after I hit enter twice. It is there after I strike enter the first time, but the second enter makes it disappear
    Help~
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,058
    What size is this mysteriously disappearing text?
    Are you drawing your model space objects full size as recommended?
  5. #5
    Junior Member
    AutoCAD 2008
    Apr 2010
    20
    Check what size your annotation text is.....depending on how you scaling your drawing the annotation may be extremely small or large. This could cause the text to "disappear" after the final enter.
  6. #6
    Full Member
    AutoCAD 2010
    Aug 2010
    44
    I appreciate everyone's input. All of my layers are 'on' and I tried typing on the 'object' layer that was obviously 'on' and nothing happened. As far as the size of the text, I had it set at .8 which is what I always use. I tried zooming in and did not see anything and I tried zoom to extents and it did not help. I am sure it is something basic, but I am lost.
    This will probably confuse things, but there was a message above the command window which read:
    Current text style: NOTES Text Height: 3.000 Annotative: yes
    I did not set up a style named NOTES, so I do not know where that came from
  7. #7
    Full Member
    AutoCAD 2010
    Aug 2010
    44
    Just another note, when I opened the drawing this morning I got a splash screen which read:
    Select Annotation Scale:
    You are selecting an annotative object. Set the annotation scale to the scale
    At which the annotation is intended to display.
    1:1
    Can anyone point me to what this is talking about? I thought you always entered measurements at a 1:1 scale. Long story, but I am not intending on printing this drawing out at this time? Also, I opend a drawing I had worked on previously and there was no problem entering and reading text.
  8. #8
    Full Member
    AutoCAD 2010
    Aug 2010
    44
    I amm still confused bsed upon my two statements above, but apparently it is an issue of my text being too small to view unless I really zoom in. Again, I don't understand why it got so small. But thanks for everyone's help so far
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    This may be a reminder that the command window gives useful information.
    Whenever Dtext is started, it always gives the current textstyle and height, so perhaps you did not notice it before
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,058
    Was it your intention from the very beginning to use Annotative Scaling for your text? Yes/No?
  1. Replies: 5
    Last Post: 9th Feb 2010, 01:37 am
  2. change from single line text to multiline text
    By zarzar in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Oct 2009, 11:12 am
  3. converting lower case text to to capital text
    By REIVAX in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2009, 11:36 am
  4. Replies: 7
    Last Post: 20th Nov 2008, 01:33 pm
  5. Replies: 0
    Last Post: 6th Sep 2006, 09:19 am
