Retaining settings upon exit
seila
When I open a drawing with specific settings (eg. style width is .9), it reverts to 1.0. I change it back to .9 and then save the drawing. When I open it again, it's reverted back to 1.0. This is also happening with LTScales. Is there a setting in ACAD that I don't have set correctly?
Congrats on your first post, and welcome to the forums!
Both the textstyle and ltscale system variables are saved within the drawing.
If you've properly modified the textstyle (i.e., using the ._style command), and the textstyle has been changed after re-opening the drawing, then perhaps there's some setting being loaded by your employer (maybe in ACADDOC.lsp)?
The same could be true for ltscale.
