Results 1 to 7 of 7
Thread: Google Sketch
    Junior Member alam k's Avatar
    AutoCAD 2010
    Oct 2010
    England
    18
    Default Google Sketch
    Has anybody tried Google's version of CAD ??? its called Google Sketchup.
    Super Member JBullseye74's Avatar
    Construction
    JBullseye74's Discipline Details
    Facade Designer
    Construction
    AutoCAD 2013
    Feb 2006
    UK North West
    768
    There is a sketchup section toward the middle of the forum under digital design. But yes many of us use Sketchup on a weekly basis.
    AutoCAD 2010
    '"Accept that some days you're the pigeon, and some days you're the statue."
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    756
    SKETCHUP IS GOOD BUT IT ISN'T THE SAME AS AUTOCAD.
    (sorry about the caps, didn't mean to shout!)
    AutoCAD 2010
    Oct 2010
    England
    18
    Dont worry designerstuart i just wanted to know. im new to autocad im takin a course on it once a week. this year im only doin the 2d designs so im gonna need all the help i can get from you guys someone introduced me to sketchup but i just wanted to know which one was better and easier!
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    AutoCAD and SketchUp are not the same type of software. Each has its strengths and weaknesses compared to the other. If I were an architect I might use AutoCAD for the actual design work but use SketchUp for all my presentation work. AutoDesk released something that is supposed to be very similar to SketchUp called Impressions. Visit the AutoDesk website for further information.
  6. #6
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,630
    I'd say if you quickly want to make a model to show design intent or produce a presentation rendering then Sketch-Up's (probably) the one which would use the least amount of your time.
    If you want to take that further into construction documentation then SK isn't too good. There are other programs which tie into SK and try to provide this functionality (e.g. Layout) but they're a far cry from the power of AC / Revit. AC isn't as great when you're going to do 3D stuff, but it's still possible. Then the verticals of AC (e.g. Mech / ACA / etc.) make life simpler for a particular type of designer. For me I choose Revit since it's close to the simplicity of SK to get a quick model out, but with a LOT more power, better quality rendering built-in, more industry specific tools, direct live technical drawings from (and to) model (you change the one and the other is updated accordingly), full BIM support, automatic schedules, etc. - not to mention it works seamlessly to and from ACad for those more complex 2D detail drawings, which has no better alternative than ACad (or its clones), using AC with SK is (sarcastically) "less than perfect".
    So basically what I'm saying is: "It depends on what you want out of it. The right tool for the job is also a subjective choice."
  7. #7
    Senior Member marmo's Avatar
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    117
    Hi,
    In my opinion it depends on the version of AutoCAD.
    At first Sketchup had commands that AutoCAD not had, as the press-and-pull for example, and also had better graphics, similar to the existing visual styles in AutoCAD.
    Altogether easy and smart.
    AutoCAD now has all these features that made sketchup new and interesting.
    The rendering is better than AutoCAD, AutoCAD works with Mental Ray the old engine of 3DMax, that is very good.
    The only -but significant- negative characteristic of AutoCAD compared with Sketchup is that Google's software works with rendering engines as VRay and Maxwell Render (installed as plug-ins), that are very powerful, better than basic AutoCAD's engine.
  1. Google
    By Tankman in forum Map 3D
    Last Post: 10th May 2010, 03:56 pm
  2. Google Earth
    By Mr.Alex in forum AutoCAD General
    Last Post: 1st Feb 2010, 07:39 pm
  3. inventor sketch to autocad sketch posible?
    By matulja87 in forum Autodesk Inventor
    Last Post: 11th Aug 2009, 03:11 pm
  4. Google Earty + CAD
    By therock005 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2008, 03:43 pm
  5. Google Earth
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 8th Aug 2006, 10:19 pm
