Hi,
I hope I'm not far off..trying to quick select all mlines and extend all 2"...Unfortunately, I soon discovered I couldn't use a lisp Lee generously provided to post studs/point loads (shown 4" solid blocks) at the end of all the beams/hdrs very effectively unless they extended 2" over the wall. I did finally worked out my first lisp first lisp ever while trying to work this out! It quick selects all mlines..haha. Below is the code I was hoping to modify for the 2" extend on both ends..Appreciate all help.
Code:--------------------------------------------------------------------- (defun c:EXTENDMLINES (/ lSet tmp doMode objLst actDoc) ;; *lDel global variable remembered during session (or *lDel (setq *lDel 2.0)) ; default value (princ "\n>>> Select lines to extend/reduce <<< ") (if (setq lSet (ssget ":L" ; reject locked layers '((0 . "*,MLINE") (8 . "str-txt") ) ) ) (progn ;; Get length to extend, Enter uses default length (initget (+ 2 4)) ; No zero, no negitive (cond ((setq tmp (getdist (strcat "\nSpecify delta: <" (rtos *lDel 2 2) "> "))) (setq *lDel tmp)) ) ;; Get Mode, default to "Both" (initget "Positive Negative Both") (cond ((null (setq doMode (getkword "\nSpecify direction [Positive/Negative/Both] <Both>: "))) (setq doMode "Both")) ) ;; Convert selection set to a list of objects (setq objLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex lSet))))) (vla-startundomark (setq actDoc (vla-get-activedocument (vlax-get-acad-object)))) ;; Lengthen the lines (foreach ln objLst (if (member doMode '("Negative" "Both")) (vlax-put ln 'startpoint (polar (vlax-get ln 'startpoint) (vlax-get ln 'angle) (- *lDel)) ) ) (if (member doMode '("Positive" "Both")) (vlax-put ln 'endpoint (polar (vlax-get ln 'endpoint) (vlax-get ln 'angle) *lDel) ) ) ) (vla-endundomark actDoc) ) ) (princ) ) (prompt "\nLengthen Lines Loaded, Enter extendmlines to run.") (princ)/(defun c:QSML2 (/ ss)
(sssetfirst nil (setq ss (ssget '((0 . "MLINE")))))
