Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Default topography / survey points
    is it possible to create a surface quickly in Autocad using 3d survey points on a DWG?
    The way I did it was 3dpolylines and then lofting the surfaces. Quite time consuming. Hoping for a faster way.
    Senior Member marmo's Avatar
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Default Dtm
    Step 01_ lisp DTM: If you have a cloud of points you cant triangulate points with 3dface.
    Step 02_lisp Autocurve: You can draw curves on 3dface of DTM
    Step 03_lisp LV_curve to mesh:
    Step 04_famous lisp M2S, mesh to solid:
    File zip with commands lisp:
    01_DTM_AC_C2M_M2S.zip
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Lisp curve to mesh works only with line: need to explode pline obtained with Autocurve.
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Default For complex structure
    Step 01, lisp mesh 2 point --> If tou have a mesh, obtained with previous posted lisp, or EDGESURF, or a primitive mesh object you can insert points on al vertex of mesh
    Step 02, lisp nodesert --> After you can insert block or 3dblock on obtained points.
    Step 03, lisp sweep with multipath --> You can explode mesh, convert 3dface in surface and extract edge (after use overkill of express tools)
    Zip files with lisp:
    02_M2P_NS_SWMP_ZETA.zip
  5. #5
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Default MESH to LOFT SURFACE!
    I apologize: lisp is in italian language and i'm not able to modify for translation.
    But I decided to post it because it works differently than MeshToSolid lisp.
    You have your mesh:
    With ths setting:
    With this setting:
    Red = solid
    Blue = loft surface
    Yellow = loft section
    File zip with lisp:
    10_MeshToSurf.zip
  6. #6
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Default Referred to MeshToSurf
    Difference between mesh an loft surface
    Difference between lisp M2S and MeshToSurf (above) and difference between command Thicken ("Ispessisci" in italian) and Ticken by MeshToSurf.
  7. #7
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Default The beginning: IF I do not have a points cloud?
    At worst you can have only a block with attribute that indicates the Z of the land.
    This lisp is able to draw a point to Z given the TAG of the block.
    Lisp file:
    04_ATT 2 POINTS_ENG.lsp
  8. #8
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    All posted lisp are free.
    I will never stop to thank those who wrote them.
    Marco
  9. #9
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    The triangle with the command DTM is accurate. Thus, such as the creation of the solid with the M2S lisp.
    The mesh creation or the Loft is approximate.
  10. #10
    Senior Member rvpas's Avatar
    rvpas's Computer Details
    Seven Pro
    laptop HP EliteBook 8760w - workstation hp
    Architectural
    rvpas's Discipline Details
    building CAD designer and AUTOCAD ATC instructor free lance
    Architectural
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    AutoCAD 2015
    Apr 2010
    Rochester NY
    180
    Hello,
    Great method for triangulate a terrain, to complete, you can use Excel or the other one to create a script.
    1 - create an additional column and in this one types the following formula: ="_point "&E2&","&F2&","&G2 see image (cells value depend your table)
    2 - copy out your formula up to the last point
    3 - copy the column
    4 - in Autocad, in the line of command, paste your list and there you will see Autocad creating automatically your points.
    The only difference it is because later, I use an add-in in Autocad FLASHCDN but who and paying to it and I think it only for french autocad version.see link (http://www.delicad.com/autocad/flashcdn.htm or http://www.delicad.com/anglais/flashmnt.php)
    At least the method of Marmo has the advantage to be free.
    thanks Marmo
    Good luck
  1. Import Survey points to Attributes
    By SSmallwood in forum AutoCAD General
    Last Post: 8th Jun 2013, 04:02 pm
  2. Old style survey points
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2010, 05:15 pm
  3. Import Survey Points?
    By rlshound in forum Civil 3D & LDD
    Last Post: 9th Feb 2010, 01:12 am
  4. Creating surfaces from survey points
    By paulgomes in forum Civil 3D & LDD
    Last Post: 7th Jan 2010, 03:01 am
  5. Creating surfaces from survey points
    Last Post: 19th Jan 2009, 04:24 am
