Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 35
  1. #21
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    dtmrnd and 2000pt.dwg both seem to work. I will assume the file I am having trouble with is the file and not the lisp. No big deal. We have another project that may come up where this will come in handy, but it is rare (3rd time in 6 years).
  2. #22
    Senior Member marmo's Avatar
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Ho qball,
    There is an application of AutoCAD called "Point Clouds" of software house Sycode.
    It 's a paid software, but once installed it allows you to make 10 free runs or for 10 days.
    I tried to test it on a tube with a pointed LaserScan.
    I modeled the pipe with only two "bas-relief" (in reality it would take many more) and although I have not had many opportunities to experiment, I think that is accurate, and has never generated errors.
    Regards
  3. #23
    Junior Member
    Map 3D 2011
    Jul 2010
    21
    Is it also possible to use these lisps on contour lines in stead of point measurements?
  4. #24
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Hello, you're welcome Nuttieke
    I'm sorry, could you explain. .I do not understand what you mean.
    Regards
  5. #25
    Structural
    Structural
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Quote Originally Posted by Nuttieke View Post
    The LV lisp should work if you explode your contour lines. Try it out.
  6. #26
    Junior Member
    Map 3D 2011
    Jul 2010
    21
    I tried it, but the contour lines are not accurate enough, I think.
  7. #27
    Forum Newbie
    AutoCAD 2008
    Nov 2010
    4
    Brilliant guide & post, Thanks very much
  8. #28
    Full Member oliver's Avatar
    Mechanical 2011
    Mar 2009
    60
    got..loading...it says (i have 2579 points loaded)
    (points coordinates may be too large - move closer to 0, 0 and/or scale down)
    if i should move all the points or coord. are not in right position.
    any suggestion regarding this matter.
    thanks
    oliver
  9. #29
    Forum Newbie
    AutoCAD 2008
    Nov 2010
    4
    Managed to get it to work with 10,000+ points.
    Took a while though
  10. #30
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Hi Oliver,
    generally when you use a software modeler is very important not to have too much difference between the scale of the model and measurement units sistem. It's also very important to not have the model away from the origin, to reduce the possibility of generating errors in the forms.
    "(points coordinates may be too large - move closer to 0, 0 and/or scale down) "
    This is a message that tells you the DTM lisp?
  1. Import Survey points to Attributes
    By SSmallwood in forum AutoCAD General
    Last Post: 8th Jun 2013, 04:02 pm
  2. Old style survey points
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2010, 05:15 pm
  3. Import Survey Points?
    By rlshound in forum Civil 3D & LDD
    Last Post: 9th Feb 2010, 01:12 am
  4. Creating surfaces from survey points
    By paulgomes in forum Civil 3D & LDD
    Last Post: 7th Jan 2010, 03:01 am
  5. Creating surfaces from survey points
    Last Post: 19th Jan 2009, 04:24 am
