Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 35 of 35
  1. #31
    Senior Member marmo's Avatar
    AutoCAD 2010
    Jun 2010
    Milan, Italy
    190
    Hi Nuttieke,
    "I tried it, But The contour lines are not accurate enough, I think."
    It 's true, if you need precision the only sure method is the triangulation with the DTM.
    They are also precise the curves obtained with the lisp AC (autocurve).
    If you need a accurate solids you must obtain directly from 3DFACE of DTM.
    Mesh and the Loft, are only approximations ...
    Useful for presentations, because they have "clean" geometries of wire mesh and smooth Loft solid.
  2. #32
    Full Member oliver's Avatar
    Mechanical 2011
    Mar 2009
    60
    @ marmo
    yes
  3. #33
    Forum Newbie
    AutoCAD 2012
    Apr 2011
    3
    Hi,
    Is it possible to move block or text to surface created with these tools without civil 3d?
    Thanks
  4. #34
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,261
    If DTM fails, review this thread...
    Slow but if no points overlap - recommended to do OVERKILL before using code - result is guaranteed...
    Regards, M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  5. #35
    Forum Newbie Amany AST's Avatar
    Architectural
    AutoCAD 2017
    Oct 2017
    1
    best post ever about Topography
    thank u
  1. Import Survey points to Attributes
    By SSmallwood in forum AutoCAD General
    Last Post: 8th Jun 2013, 04:02 pm
  2. Old style survey points
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2010, 05:15 pm
  3. Import Survey Points?
    By rlshound in forum Civil 3D & LDD
    Last Post: 9th Feb 2010, 01:12 am
  4. Creating surfaces from survey points
    By paulgomes in forum Civil 3D & LDD
    Last Post: 7th Jan 2010, 03:01 am
  5. Creating surfaces from survey points
    Last Post: 19th Jan 2009, 04:24 am
