Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2005
    Jul 2010
    9
    Default text height and dimensioning scale
    Hi All hope someone can help or point me in the right direction. I've just started a new job and am going to be using Autocad 2010.
    When I've created a drawing and come to adding text what text height should I be specifying or how do I work out correct text height to use?
    If I've created for example a layout at 1:100 scale and details at 1:10 scale using different viewports in paper space should I be creating different text heights or is using annotaive text the best option?
    Also what text height should I set-up for dimensioning to make sure all text heights are the same for the 1:100 layout and 1:10 details?
    Thanks in advance for any help.
    Mark
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    The size of your dimension text is between you, your company, and your clients, but generally it will be somewhere between 3/32" and 3/16" when printed. I personally like to place my dimension while working in the scaled viewport, and let AutoCAD automatically scale the dimension relative to the viewport scale so it will aways print the size I specify without ever having to set or change dimension scales. You'll probably get different advice from others, so I recommend you try each method and print them out so see which suites you best.
    Here's a related topic that pretty much covers all the different options. I posted a screenshot of the method I use in post #32 http://www.cadtutor.net/forum/showth...782#post356782
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    New users of AutoCAD are encouraged to use Annotative Scaling. This will ensure that no matter what scale is assigned to what viewport in your layout that all the text will be the same height when viewed in the layout and when printed. It means you'll have to deal with scalelists. A piece of text and/or a dimension may have more than one scale assigned to it.
    Forum Newbie
    AutoCAD 2005
    Jul 2010
    9
    Thanks all for your quick responses and advice.
    I'm sure I'll be back asking for more advice in the near future!
  5. #5
    Full Member
    AutoCAD 2010
    Oct 2010
    37
    I wouldn´t use annotative texts, cause the texts might go through the drawings. I would suggest making a text style for 1:100 and one for 1:10. Than you can directly see how things will be in the end.
    Never trust a pc
  6. #6
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    755
    Quote Originally Posted by Rob S View Post
    Never trust a pc
    Why would you say that? The reason AutoDesk added Annotative objects was to avoid just what you are suggesting.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
  7. #7
    Full Member
    AutoCAD 2010
    Oct 2010
    37
    Quote Originally Posted by kencaz View Post
    KC
    I can understand what they tried. For me it is not working that well. I am working in civil engineering and when I use annotative texts for different scales it always goes through lines. That doesnt make the text readable. That is why I dont like using annotative objects.
  1. text height
    By gmdr in forum AutoCAD Beginners' Area
    Last Post: 26th Jan 2009, 08:38 pm
  2. dimensioning in scale
    By Navarone in forum SolidWorks
    Last Post: 28th Mar 2008, 10:49 am
  3. Annotative Blocks that Scale according to Text Height
    By xspacex in forum AutoCAD Drawing Management & Output
    Last Post: 1st Mar 2008, 03:17 am
  4. Text height
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2005, 05:05 pm
  5. Text Height
    By hyposmurf in forum AutoCAD General
    Last Post: 2nd Jul 2003, 02:54 pm
