Guest balajibth84 Posted October 11, 2010 Share Posted October 11, 2010 Hai Here Balaji...I want insert the Block using lisp...Ex:In my Block i have created the Blockname is 1,2,3... Now i want insert the block 1 means just single command like 1 means its need to place to with that as it is angle....For u r reference here i have attached the Dwg also.....Can u help????for this..I am using Cad 2007......For_Test.dwg Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 12, 2010 Share Posted October 12, 2010 Hai i am expect the reply..Anybody seen this query??? Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 12, 2010 Share Posted October 12, 2010 Try this: (you need to be patience(?) http://www.theswamp.org/index.php?topic=34348.0 Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 12, 2010 Share Posted October 12, 2010 I have multiple combination(More Different Blocks) of blocks......For this insert block we r spending the time.....Just i want place manually...Suppose i want place some combination of blocks.... *****After insert command Just i will give that Block name means its should be place where i am picking...And angle as per block angle its maintain means also its well enough...I am using Cad 2007 Version.....***** ... Thanks in advance........... Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 12, 2010 Share Posted October 12, 2010 People are probably a little gun shy. http://www.cadtutor.net/forum/showthread.php?53026-Calculator-for-Adding-and-Multiple..... Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 12, 2010 Share Posted October 12, 2010 For this Link nothing is availble..Then y u r mentioned Alanjt????? Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 12, 2010 Share Posted October 12, 2010 It was an answer to possibly why no one has responded to your thread. To answer your question, choose one of the three following options: (command "_.-insert"...) (vla-insertblock ... (entmakex (list '(0 . "INSERT") ... Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 12, 2010 Share Posted October 12, 2010 It was an answer to possibly why no one has responded to your thread. To answer your question, choose one of the three following options: (command "_.-insert"...) (vla-insertblock ... (entmakex (list '(0 . "INSERT") ... Hai plz tell clearly..Step by Step.....Lisp is not possible????Now we r using more blocksSuppose we r using any option means its takng more time....So only i am asking the Lisp code... Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 13, 2010 Share Posted October 13, 2010 It was an answer to possibly why no one has responded to your thread. To answer your question, choose one of the three following options: (command "_.-insert"...) (vla-insertblock ... (entmakex (list '(0 . "INSERT") ... Hai As per this I have prepared shortcut....Actually we are using morethan 200 blocks...Plz see below mentioned Lisp... (defun c:100100() (command "_.-insert" "MC100-MC100" "R" "0" )) (defun c:100125() (command "_.-insert" "MC100-MC125" "R" "0" )) (defun c:100150() (command "_.-insert" "MC100-MC150" "R" "0" )) (defun c:125125() (command "_.-insert" "MC125-MC125" "R" "0" )) (defun c:125100() (command "_.-insert" "MC125-MC100" "R" "0" )) (defun c:125150() (command "_.-insert" "MC125-MC150" "R" "0" )) (defun c:150150() (command "_.-insert" "MC150-MC150" "R" "0" )) (defun c:150100() (command "_.-insert" "MC150-MC100" "R" "0" )) (defun c:150125() (command "_.-insert" "MC150-MC125" "R" "0" )) (defun c:MC150-MC200() (command "_.-insert" "MC150-MC200" "R" "0" )) (defun c:200200() (command "_.-insert" "MC200-MC200" "R" "0" )) (defun c:200150() (command "_.-insert" "MC200-MC150" "R" "0" )) (defun c:2032520325() (command "_.-insert" "UB203X133X25-UB203X133X25" "R" "0" )) Actually i am Insert the Blocks using that blocks name....Now we have 200 hundred blocks..So for that 200 block i cannt create this...So i am taken that block naqme..So hw to update for all blocks???to this lisp???Any idea????oterwise i want prepare 200 times same???(See i have mentioned Block name and Shortcut command) Quote Link to comment Share on other sites More sharing options...
BlackBox Posted October 13, 2010 Share Posted October 13, 2010 Hi Balaji, Please understand... I believe this is not your intention, but some people receive your posts to be impatient, demanding, and even rude. We want to help you, but only if you are patient, understanding, and kind. Thank you for considerring my request. :: BACK ON TOPIC :: As another option, have you considered creating a Tool Palette for your 200 blocks instead of writing LISP for each? A Tool Palette is easy to create, maintain, and share between users. Hope this helps! Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 13, 2010 Share Posted October 13, 2010 Hi Balaji, Please understand... I believe this is not your intention, but some people receive your posts to be impatient, demanding, and even rude. We want to help you, but only if you are patient, understanding, and kind. Thank you for considerring my request. :: BACK ON TOPIC :: As another option, have you considered creating a Tool Palette for your 200 blocks instead of writing LISP for each? A Tool Palette is easy to create, maintain, and share between users. Hope this helps! You beat me to it, but I completely agree. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted October 13, 2010 Share Posted October 13, 2010 You beat me to it, but I completely agree. Thanks, Alan. :wink: Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 13, 2010 Share Posted October 13, 2010 Hi Balaji, Please understand... I believe this is not your intention, but some people receive your posts to be impatient, demanding, and even rude. We want to help you, but only if you are patient, understanding, and kind. Thank you for considerring my request. :: BACK ON TOPIC :: As another option, have you considered creating a Tool Palette for your 200 blocks instead of writing LISP for each? A Tool Palette is easy to create, maintain, and share between users. Hope this helps! ohhh.i understood.Tool palette means how to create???How to Include all blocks to that tool pallete???Plz tell step by step..Iam waiting for u r hope ful reply....???? Quote Link to comment Share on other sites More sharing options...
BlackBox Posted October 13, 2010 Share Posted October 13, 2010 I appreciate your liking my suggestion, but did you understand my request in the first part, my friend? ohhh.i understood.Tool palette means how to create???How to Include all blocks to that tool pallete???Plz tell step by step..Iam waiting for u r hope ful reply....???? Here is a link to a tutorial that might help you: AutoCAD 2004 Customization Tutorial: Creating a New Tool Palette The tutorial uses AutoCAD 2004, but it will still work for you using 2007. Not sure about Mechanical? Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 13, 2010 Share Posted October 13, 2010 It was an answer to possibly why no one has responded to your thread. To answer your question, choose one of the three following options: (command "_.-insert"...) (vla-insertblock ... (entmakex (list '(0 . "INSERT") ... Alan you forgot to number options ie: 1 2 3 Quote Link to comment Share on other sites More sharing options...
BlackBox Posted October 13, 2010 Share Posted October 13, 2010 Alan you forgot to number options ie: 1 2 3 What happened... did you get to the second option listed and look back at the first for a reference point, and get lost among the lot? 'Number your options'... that's the funniest thing I've read today . Thank you! Edit: And he gives an example!! lmao Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 13, 2010 Share Posted October 13, 2010 I think is less time consuming just to pick number instead of retyping line of code...LOL Can it be done with lisp? (number picking) Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 13, 2010 Share Posted October 13, 2010 Alan you forgot to number options ie: 1 2 3 I don't even know how to respond to that. I think is less time consuming just to pick number instead of retyping line of code...LOLCan it be done with lisp? (number picking) Huh? Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted October 13, 2010 Share Posted October 13, 2010 I don't even know how to respond to that. Huh? Just:D:D:D Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 17, 2010 Share Posted October 17, 2010 (edited) It was an answer to possibly why no one has responded to your thread. To answer your question, choose one of the three following options: (command "_.-insert"...) (vla-insertblock ... (entmakex (list '(0 . "INSERT") ... Hai Barry Here Balaji. I have Shortcut for Blocks insert.We are using more blocks.Now i want insert the blocks using Shortcuts Lisp means Its asking X scale factor Y scale factor And Rotaion Angle. So in my Lisp I want to add: X scale factor is 1 Y scale factor is 1 and Rotation Angle is 0. So in below mentioned Shorts Cuts How to include this Scale Factor and Rotation Angle Values?Please Help me. (defun c:T506() (command "_Insert" "T506" )) (defun c:T656() (command "_Insert" "T656" )) (defun c:T756() (command "_Insert" "T756" )) And One more thing.. We are Using So many blocks More than 350..Now i want create that black short means each and every time i want paste this code.. (defun c:XXXX() (command "_Insert" "XXXX" )) If its possible i want update latest updation to that single place.Like that lisp having some adding the next block list means easily i will add that..Like T506 Blocname--->ShortCut Command is T506 T500 Blocname--->ShortCut Command is T500 T600 Blocname--->ShortCut Command is T600 What ever in Block name directly i want use that name in command line means its need to insert...With Astual Size.So i want X scale factor is 1 Y scale factor is 1 and Rotation Angle is 0. Edited October 17, 2010 by balajibth84 For Multi BlockInsert in Single Lsp Quote Link to comment Share on other sites More sharing options...
