fatal error e0434f4dh exception at 75ac9617
bsimpson
Hi,
I am running AutoCAD 2010 and an error with drawing1.dwg occurs fatal error e0434f4dh exception at 75ac9617 everytime I open the program.
The program dose not run anymore but gives the error message.
What can I do?
bsimpson
Have you conducted an Internet search or one of the AutoDesk website to see if this specific error is a known problem?
You're telling us that AutoCAD will not open any drawings at all?
Thats correct AutoCAD 2010 does not open and an new error message gives
e0434f4dh Exception 756c9617h
I am currently surfing for a solution but nothing found yet.
bsimpson:shock:
From Autodesk
"The problem was suspected to lay with one of the Microsoft .NET
Framework installations so I removed .NET Framework 2.0 and the fatal
error went away"
If indeed that is the cause of the problem the OP will need the .NET framework removal tool. He should NOT use the Add/Remove programs that come with XP or Vista.
Agreed. Maybe a Windows Update, or a re install of acad before attempting that?
The net frame work from microsoft has a version 4 which I tried I also tried updating windows. but nothing. Its best I fix the problem before repairing autoCAD 2010
I would have recommended trying the REPAIR option FIRST rather than swapping out .NET Framework.
How did you "try" .NET FRamework ver 4?
What do you mean you also updated Windows?
I stumbled across this solution
1 Log on to the workstation as the user.
2 On the Start menu (Windows), click Run.
3 In the Run dialog box, enter regedit.
a Back up your registry , file >> export
4 In the Registry Editor, locate the following subkey and delete it:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8000:409
5 Exit the Registry Editor.
and it worked
bsimpson:D
and it worked
bsimpson:D
Thank you for posting your solution, im sure this help out people in the future!
