bsimpson Posted October 15, 2010 Share Posted October 15, 2010 Hi, I am running AutoCAD 2010 and an error with drawing1.dwg occurs fatal error e0434f4dh exception at 75ac9617 everytime I open the program. The program dose not run anymore but gives the error message. What can I do? bsimpson Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 15, 2010 Share Posted October 15, 2010 Have you conducted an Internet search or one of the AutoDesk website to see if this specific error is a known problem? You're telling us that AutoCAD will not open any drawings at all? Quote Link to comment Share on other sites More sharing options...
bsimpson Posted October 15, 2010 Author Share Posted October 15, 2010 Thats correct AutoCAD 2010 does not open and an new error message gives e0434f4dh Exception 756c9617h I am currently surfing for a solution but nothing found yet. bsimpson:shock: Quote Link to comment Share on other sites More sharing options...
JPlanera Posted October 15, 2010 Share Posted October 15, 2010 From Autodesk "The problem was suspected to lay with one of the Microsoft .NET Framework installations so I removed .NET Framework 2.0 and the fatal error went away" Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 15, 2010 Share Posted October 15, 2010 If indeed that is the cause of the problem the OP will need the .NET framework removal tool. He should NOT use the Add/Remove programs that come with XP or Vista. Quote Link to comment Share on other sites More sharing options...
bsimpson Posted October 15, 2010 Author Share Posted October 15, 2010 I am running windows 7 and the only program close to that is microsoft NET.framework 4 client profile. Shall i unistall? Quote Link to comment Share on other sites More sharing options...
JPlanera Posted October 15, 2010 Share Posted October 15, 2010 If indeed that is the cause of the problem the OP will need the .NET framework removal tool. He should NOT use the Add/Remove programs that come with XP or Vista. Agreed. Maybe a Windows Update, or a re install of acad before attempting that? Quote Link to comment Share on other sites More sharing options...
bsimpson Posted October 15, 2010 Author Share Posted October 15, 2010 The net frame work from microsoft has a version 4 which I tried I also tried updating windows. but nothing. Its best I fix the problem before repairing autoCAD 2010 Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 15, 2010 Share Posted October 15, 2010 I would have recommended trying the REPAIR option FIRST rather than swapping out .NET Framework. How did you "try" .NET FRamework ver 4? What do you mean you also updated Windows? Quote Link to comment Share on other sites More sharing options...
bsimpson Posted October 16, 2010 Author Share Posted October 16, 2010 I stumbled across this solution 1 Log on to the workstation as the user. 2 On the Start menu (Windows), click Run. 3 In the Run dialog box, enter regedit. a Back up your registry , file >> export 4 In the Registry Editor, locate the following subkey and delete it: HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8000:409 5 Exit the Registry Editor. and it worked bsimpson:D Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 16, 2010 Share Posted October 16, 2010 Glad to hear you got the problem solved and thank you for sharing the solution with us. Quote Link to comment Share on other sites More sharing options...
JPlanera Posted October 18, 2010 Share Posted October 18, 2010 I stumbled across this solution 1 Log on to the workstation as the user. 2 On the Start menu (Windows), click Run. 3 In the Run dialog box, enter regedit. a Back up your registry , file >> export 4 In the Registry Editor, locate the following subkey and delete it: HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8000:409 5 Exit the Registry Editor. and it worked bsimpson:D Thank you for posting your solution, im sure this help out people in the future! Quote Link to comment Share on other sites More sharing options...
