Results 1 to 7 of 7
    Forum Newbie
    CB89's Computer Details
    Dell Dimension E520, Win XP
    Intel Core 2 Duo 1.80GHz
    3
    Zotac GeForce 9500gt
    AutoCAD 2008
    Mar 2008
    Texas
    7
    Question self trimming block?
    hello to every one, I was looking for a way to make a block that would trim any line that would go thru it.
    For example if i have a block of a circle and it has many lines connecting to it at various angles, Is there a way to have the lines automatically trim?
    I found this Article but I am confused of how it would work with a circle.
    http://www.afralisp.net/archive/lispa/lisp52.htm
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    CB89
    Don't try to post hyperlinks, you will get your posts moderated. That means that it will appear for public only after a moderator approves it. Read the forum rules.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,138
    I've seen this feature in AutoCAD Electrical with the blocks it inserts but I wonder, since we are dealing with blocks, if the insertion actually "breaks" the line instead.
    Senior Member Cat's Avatar
    Electrical 2008
    Jul 2010
    Georgia
    147
    Quote Originally Posted by CB89 View Post
    That's a lot of code to break at two points. To use that code with a circle, you would have to have consistent specific points where any lines crossed through the circle.
    ~~~~~ Calling a professional drafter a cad technician is like calling an engineer a calculator! ~~~~~
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    If you need to 'trim' the lines for appearance purposes you can create a block that has a circle and a wipeout with a polygon as the border. It doesn't actually trim the lines, just 'hides' them. Attached is a dynamic block that is used for property corners on survey drawings.
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,791
    Another way maybe if you really want to trim rather than hide would be to have 2 blocks the first being a polyline around your block just explode then "Extrim" "last" Erase last then insert block required. You could do it as a command or a lisp.
  7. #7
    Forum Newbie
    3
    AutoCAD 2008
    Mar 2008
    Texas
    7
    Wow, thank you for all the replies. That was faster than I expected. "lpseifert" that is so simple I didn't even think about it thank you. I guess for my purposes this would be the easiest and fastest way. As to the lisp commands, I just found out about the whole programming thing a couple of weeks ago. Im still a complete noob to the whole idea but I am trying to learn with all the links from this site. (they didn't teach lisp at my high school) But I will try the different approaches.
    Thank You to everyone
    PS: Sorry about the link, like I said NOOB.
  1. Need some help with Trimming
    By didko in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2008, 09:22 am
  2. Need some help with Trimming
    By didko in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Aug 2008, 07:25 pm
  3. Trimming etc
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 24th Sep 2007, 09:15 pm
  4. extending/ trimming to nothing
    By everglade in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jun 2006, 01:57 pm
  5. Trimming
    By jonjon in forum AutoCAD General
    Last Post: 7th Jan 2006, 07:14 pm
Tags for this Thread
