salim Posted October 16, 2010 Share Posted October 16, 2010 I ma new user of Auto CAD. i was setup units decimal>precision-0.00 drawing units design center block millimeter. And dimension style > primary units same, but i right 1 in command line, it is show 1 inch, how can i set up millimeter or centimeter setup? i want i right command line 10 and it draw 10mm line. i use liner for show automatically 10mm. thank. Quote Link to comment Share on other sites More sharing options...
rvpas Posted October 16, 2010 Share Posted October 16, 2010 Hello Salim, Menu Format-->Drawing units or in command line type units and press enter Set length to milimeter Bye Pascal Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 16, 2010 Share Posted October 16, 2010 One of the first things I'd suggest is using a metric template. Quote Link to comment Share on other sites More sharing options...
rvpas Posted October 16, 2010 Share Posted October 16, 2010 Of course Remark Shame to me, New/Select acadISO.dwt or acadISO -Named Plot Styles.dwt both is a metric Template Quote Link to comment Share on other sites More sharing options...
salim Posted October 30, 2010 Author Share Posted October 30, 2010 Thank for reply. But i am face some problem again. I am trying to setup Centimeter but it is not setup.How can i setup centimeter? Quote Link to comment Share on other sites More sharing options...
rvpas Posted October 30, 2010 Share Posted October 30, 2010 Hello Salim, 1st - New/Select acadISO.dwt or acadISO -Named Plot Styles.dwt both is a metric Template, 2nd - Menu Format-->Drawing units or in command line type units and press enter Set length to centimeter And if you often needs it I you advice to create a template DWT Menu Files-->Save as-->at the bottom of dialogue box, change in file type to drawing template DWT Bye Pascal Quote Link to comment Share on other sites More sharing options...
