cadeddie82 Posted October 19, 2010 Share Posted October 19, 2010 (edited) How do I delete a point style I created (in tool space) cant seem to figure it out...kinda new to civil 3d Edited October 19, 2010 by cadeddie82 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 19, 2010 Share Posted October 19, 2010 You may have a simple task here, or you may not. The simple task is to right-click on the style in the Settings tab of Toolspace, which should give you a Delete option, which you select. The not-simple task happens when you don't get that option. Some other style depends on your point style, so you can't delete the point style until you've deleted that other style. You also need to delete every object that uses the style(s). You'll see an orange triangle before the style name if it's in use. Quote Link to comment Share on other sites More sharing options...
cadeddie82 Posted October 19, 2010 Author Share Posted October 19, 2010 wasnt able to right click and delete, I tried that from the get-go and now the orange triangles seem to be gone (for those that I worked on) 2nd day on the job here, they kinda just thru me in here! Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 19, 2010 Share Posted October 19, 2010 Find the style in the settings tab and delete from there (right-click). However, you cannot delete it if the style is being used. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 20, 2010 Share Posted October 20, 2010 Without having your drawing to look at, we can only offer general suggestions. There is something else in the drawing that you must delete before you can delete the point style. It might be the default style for a point group, a marker style, a label style, a point in the drawing, any number of things. Looking at it another way, is it critical that you delete this style? You could rename and redefine it. It shouldn't hurt anything if you leave it as is. Quote Link to comment Share on other sites More sharing options...
cadeddie82 Posted October 20, 2010 Author Share Posted October 20, 2010 Thanks for the help guys, got the ball rolling already, got mixed up that’s all I can say, and re-naming is definitely the easiest way....third day on civil 3d Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 20, 2010 Share Posted October 20, 2010 Good luck with C3D! There's a steep learning curve. And welcome to CADTutor! Quote Link to comment Share on other sites More sharing options...
