Coaster Posted October 20, 2010 Share Posted October 20, 2010 Hi, I want to save an image of a rendering in autoCAD, but whenever I try 'saveimg', 'jpgout' or 'export', autocad freezes and I eventually have to shut it down manually. I can't seem to find anyone having this problem. Why does this happen? The problem is not on a particular file, because even with a new file this problem occurs. Any help will be appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 20, 2010 Share Posted October 20, 2010 Are you rendering to the render window or to the viewport? If you're rendering to the viewport, try rendering to the window instead and then save the image from there. Someone else just asked a similar question a few days ago. Have a look at this thread: http://www.cadtutor.net/forum/showthread.php?53388-Saving-printing-a-rendered-3d-drawing What are your full computer specs? Maybe you need more RAM? Quote Link to comment Share on other sites More sharing options...
Coaster Posted October 20, 2010 Author Share Posted October 20, 2010 Thank you for your reply! I am actually rendering to the window and, within autocad, i can perfectly see the rendered image. The problem is when I try to put it in a file. The moment I click the '...' button in the 'Output File Name', in the 'Advanced Render Settings' window, autocad crashes. My specs are: Memory: 4 GB Processor: Intel Core2Duo 6300 @ 1.86GHz OS: Windows 7 x64 Graphics Card: ATI Radeon HD 4850 512 Mb Quote Link to comment Share on other sites More sharing options...
