polyline coordinates
eg0n
Hi, i'm still a beginner in lisp and need some help. I want to use some algorithms to simplify a 2D polyline but I don't know how to store the coordinates of each vertex in a different variable.
thank you in advance
Since the total number of vertices will be unknown I think the best approach is to create a list of the vertices then access then using then nth function or the forecah function.
Without knowing what you plan to do it is difficult to give a direct answer. If you could post you code it would be helpful
