Results 1 to 4 of 4
    Junior Member
    AutoCAD 2013
    Sep 2010
    15
    Default Crosshair color display in 2011 paperspace makes it hard to see
    I like my paperspace Uniform Background set to black, which worked fine in 2010. The crosshair displayed white over the black paper area, and inverted to black over the grey background outside the paper.
    In 2011 the background area is much lighter, and the crosshair does not invert. So when I set the paper background to black the crosshair turns white and becomes almost invisible when its outside the paper. This causes me to frequently "lose" the cursor location so I have to wiggle it around until it crosses something that allows me to see it.
    The only thing that helps is to turn off "Display Paper Background" in the display options, which makes everything black. This is a lousy solution.
    Anyone else had this issue or know a solution? Is it a bug? The 2010 behavior obviously makes more sense.
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    I do not have 2011 software, but as a supplement to the 'lousy solution' you've already noted... I typically check the 'Display printable area' box in options, so I can still see what will print.
    Good luck!
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Super Member nukecad's Avatar
    nukecad's Computer Details
    Win 10 home.
    Various machines.
    AutoCAD 2000i
    Apr 2009
    NW Cumbria (English Lake District)
    712
    You could always change your layout space crosshairs to another colour.
    Red looks quite good on the black background and inverts to cyan over the grey paper background.
    In fact I think I will keep mine red for a while.
    *** Out of Beer Error ->-> Recovering Memory***
    Junior Member
    AutoCAD 2013
    Sep 2010
    15
    Well, the problem is that 2011 isn't inverting the color. When I set the crosshair to red with a black background its red over the black, and red over the grey.
    My solution was to keep the background white, but check "Display Plot Styles" in the page setup so that the linework is black, which makes everything visible on white, but this isn't ideal. I would rather not make changes to our files that will affect everyone who uses them when I should be able to solve the problem by changing my own settings.
    I do like the red though. It looks sharp over white with black linework, and its clearly visible over both black and grey. Win win!
    Thanks.
  1. Paperspace layout/viewport display in B&W?
    By CalypsoArt in forum AutoCAD General
    Last Post: 10th Jun 2010, 01:32 pm
  2. Crosshair Problem on 2011
    By Ocron in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jun 2010, 11:22 pm
  3. Crosshair Color
    By Burner in forum AutoCAD Beginners' Area
    Last Post: 27th Apr 2010, 11:53 pm
  4. What color is your Model/Paperspace set to????
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 11th Nov 2006, 05:21 pm
  5. Crosshair problems in paperspace!!
    By LukemanVW in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2005, 11:08 am
Tags for this Thread
