Results 1 to 9 of 9
    Senior Member
    AutoCAD 2010
    Jul 2010
    347
    Default save my dwg to D:My Folder
    Hello,
    How to save my dwg to the drive D and to specific folder . for example called My Folder.
    Code:
    (setq Fname (getstring T "\n new file name :"))
    (setq x (strcat "D:\\My Folder\\" Fname ".dwg"))
    Why the above file path is not working ?
    Thanks
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,705
    Does 'My Folder' exist?
    Lee Mac Programming
    Just another Swamper
    Senior Member
    JohnM's Computer Details
    xp pro
    AutoCAD 2006
    Feb 2009
    houston, texas
    380
    please post the rest of the code so we can see what's going on
    Senior Member
    AutoCAD 2010
    Jul 2010
    347
    Yes Lee the "My Folder" is already made or existed in drive D.
    Mr Johnm. Here are the codes nothings more than that up to this moment .
    Code:
    (if (and (setq Fname (getstring T "\n new file name :"))
    (command "_.save" x)
    By Mr Lee 's question, Is it possible also to create a folder before save the dwg and include it within ?
    many thanks for you all.
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,705
    Perhaps something like this...
    Code:
    (defun c:test ( / dir file )
      (setq dir "D:\\My Folder")
      (vl-mkdir dir)
      (if (and (vl-file-directory-p dir)
               (snvalid (setq file (getstring t "\nEnter Filename: ")))
        (vla-saveas (vla-get-ActiveDocument (vlax-get-acad-object))
          (strcat dir "\\" file ".dwg")
    Lee Mac Programming
  6. #6
    Senior Member
    AutoCAD 2010
    Jul 2010
    347
    Quote Originally Posted by Lee Mac View Post
    Code:
      (vl-mkdir dir)
          (strcat dir "\\" file)
      (princ))
    What a great work Lee.
    That's really amazing and wonderful.
    one question please about (snvalid). I've read about it but I couldn't understand it well ?
    Thank you so much.
    Michaels
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,705
    Thanks Michaels
    snvalid checks whether the string is valid for use as a symbol table name, hence it checks for characters such as /\?*" etc - the help files document it better.
    (BTW, I updated the code above to include the .dwg extension)
    Lee Mac Programming
  8. #8
    Senior Member
    AutoCAD 2010
    Jul 2010
    347
    That's right. The first code that you posted before post 5 and re update it within the same reply , it did not work because it was (saveas) and I tried it with (save) command only and it was as great as the the last undated one.
    Thank you so much Lee.
  9. #9
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Further on Lee's teaching career see This Thread.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  1. Why can't I save a DWT to a custom folder?
    By CADnewb in forum AutoCAD Beginners' Area
    Last Post: 18th Oct 2010, 12:48 am
  2. Autocad doesn´t prompt to save, just save
    By gilsoto13 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 7th Apr 2010, 08:08 pm
  3. Replies: 1
    Last Post: 6th Oct 2008, 09:40 pm
  4. VB to select input folder and output folder
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jun 2007, 11:07 pm
  5. Fatal error during automatic save or manual save
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 11th Sep 2006, 08:50 pm
