Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2010
    Oct 2010
    4
    Default Installation Errors
    Hi all,
    Im getting pretty fed up with getting the same error messages when trying to install the trial of autocad. I have seen .NET Framework 3.5 under the control panel on my PC and have installed .Net framework 4. During the installation I keep getting a red X by .Net Framework 3.5 SP1.
    DirectX 9.0 Runtime gets a green tick during installation however I get 5 alerts stating the following Error messages:
    AutoCAD 2010 Internal Error 2908 {9CBD4DFA-A2E4-405E-8FFB-6A4CEB9CBA3D}
    AutoCAD 2010 Internal Error 2908 {5EFBCC69-34A5-47258F6D98110A82B05B}
    AutoCAD 2010 Internal Error 2908 {A22E3DB9-BA62-4477-AF95-3189E7B06132}
    AutoCAD 2010 Internal Error 2908 {D6CC68E0-A5D6-43A7-B105-4FCFEF3745D6}
    AutoCAD 2010 Internal Error 2908 {8792605A-AB16-4D2B-9718-76564419254}
    What the hell do these mean!? Ive Googled them and nothing!
    During the AutoCAD 2010 part of installation the final alert says the following:
    Error 1935. An error occured during the installation of assemble 'Autodesk.AutoCAD.Interop,version='17.1.51.0", publicKeyToken= "eed84259d7cbf30b",processsorArchitecture= "MSIL" '. Please refer to Help and Support for more information.
    I have no idea on what to do, someone please help as I have to use this for some work!!
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    Did you create a Restore point prior to attempting to change .NET framework and/or loading AutoCAD?
    Forum Newbie
    AutoCAD 2010
    Oct 2010
    4
    yes, the computr created a restore point itself however after installing framework 4 the problem still occurs
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    Did you use the recommended procedure for uninstalling the old version of .NET framework and installing the newer version?
    You are aware at this point that AutoDesk does not recommend using .NET Framework 4 right?
    What OS are you running? What version? Is it 32-bit or 64-bit?
  5. #5
    Forum Newbie
    AutoCAD 2010
    Oct 2010
    4
    I went through Add/Remove on the control pannel. after the installation i have also tried to use the repair option
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    Then that could be part of your problem re: .NET Framework. Click on the link below. Scroll down to post #4 out of 6 and read it. This outlines the procedure you should have followed.
    http://forums.autodesk.com/t5/Instal...d/td-p/2757591
  1. AutoCAD LT 95 installation
    By njs500 in forum AutoCAD Museum
    Last Post: 14th Mar 2012, 05:16 pm
  2. Re-Installation of Cad
    By scoffagus in forum AutoCAD Beginners' Area
    Last Post: 18th May 2010, 12:10 am
  3. Installation Problems
    By FIFTHTEXAS in forum Autodesk Inventor
    Last Post: 29th Nov 2006, 06:55 pm
  4. Using log to troubleshoot installation errors
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 14th Nov 2006, 05:48 pm
