Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Full Member
    AutoCAD 2011
    Oct 2010
    35
    Unhappy Can't edit anything...
    I just got these messages:
    "The apperance of this object is not controlled by the display system"..
    "This object is an xref and is not editable through the display tab. Use the context menu to acces the object display properties for the xref".
    I can't use my delete button, I can't copy, move, edit blocks etc.
    What has happened and how do i change my Acad back to normal??
    Thanks!!!
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    Its not a block judging from the message, it's an x-ref. And an X-ref you can't edit in the same way, it is its own file somwhere. Bring up the External Reference manager and find the search path for it.
    Oh, and please don't double post.
    MTJIGSTRING = BAZINGA
    Full Member
    AutoCAD 2011
    Oct 2010
    35
    Thanks for the quick answer and sorry for the double post...
    I'm fully aware on how to manage xrefs but my real problem is the other things about not being able to edit anything. Just thought that someone maybe had seen these messages before. The actual problem is not really concerning xrefs. All my normal keyboard shortcuts doesn't seem to work. I can't even edit any text. Think i'll try to reinstall...
    HP EliteBook 8570w
    16GB
    HP
    Civil
    Education /support
    Civil
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    Aha, its a command problem.
    If you type the command as _.move (with _ and dot) does it work then?
  5. #5
    Full Member
    AutoCAD 2011
    Oct 2010
    35
    Yep that works. I can also select the object, press M "enter", but then it wants me to select the object a second time and press enter again. And finally it won't snap to anything. not even the object itself.
  6. #6
    HP EliteBook 8570w
    16GB
    HP
    Civil
    Education /support
    Civil
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    try changing the variable PICKFIRST to 1
  7. #7
    Full Member
    AutoCAD 2011
    Oct 2010
    35
    GREAT!!!!!!!!!!
    It works!!!! Thank you so much, was just about to go completely mental...
    But how come it works. Can you explain what the command does??
  8. #8
    HP EliteBook 8570w
    16GB
    HP
    Civil
    Education /support
    Civil
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    PICKFIRST is a variable that controls wheter you can select objects before you input a command or have to select them after.
    It is fairly common that the variable is changed by poorly-written lisps.
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    Using poorly written code is an offense punishable by a good smack upside the head. Get ready because one is coming your way.
  10. #10
    Full Member
    AutoCAD 2011
    Oct 2010
    35
    Thanks to all...
    I have another question though... It's taking really long to plot and undo... do you know why that is??
    When I open a drawing it says: "the following shortcuts in the search were invalid and ignored; X:\Acad\plot styles\Add-A-Plot Style Table Wizard.lnk
  1. att edit help
    By daveyboyd in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2010, 03:57 pm
  2. Cannot edit!!!
    By slowsilver! in forum AutoCAD Drawing Management & Output
    Last Post: 4th Feb 2010, 07:41 pm
  3. Edit DWF
    By Fire Alarm in forum AutoCAD General
    Last Post: 10th Nov 2009, 02:29 pm
  4. edit ground in view edit corridor sections
    By ikapo in forum Civil 3D & LDD
    Last Post: 10th Apr 2009, 10:24 am
  5. 3D Edit
    By Aravinthan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Nov 2007, 11:16 am
