+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Super Moderator Tiger's Avatar
    Computer Details
    Tiger's Computer Details
    Operating System:
    Windows 7 Enterprise 64 bit
    Computer:
    Dell Precision M4500
    CPU:
    Intel Core i5 2.40GHz
    RAM:
    8GB
    Graphics:
    NVIDIA Quadro FX 880M
    Primary Storage:
    280 GB
    Monitor:
    2 x Samsung SyncMaster 2443 24''
    Using
    AutoCAD 2012
    Join Date
    Nov 2006
    Location
    Sthlm, Sweden
    Posts
    4,595
    Default
    Could be lots of reasons.
    - how's your computerspecs? Everything up to date vis-a-vi drivers, service packs and what-nots?
    - Have you defragged the comp and cleaned it from unnecessary files recently?
    - is it a large drawing? does it do the same in a new-started drawing? Lots of layers/layer states?
    - Have you run Purge/Audit lately?
    Is there a servicepack on AutoCAd 2011 that you might have missed?
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  2. #12
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,090
    Default
    Are you plotting over a network?
  3. #13
    Full Member
    Using
    AutoCAD 2011
    Join Date
    Oct 2010
    Posts
    35
    Default
    Computer specs are fine. It's during the last week or so that i have experienced these things. The comp. is pretty new so it shouldn't be a problem with defrag. etc.
    It does the same in all drawing, wether they are new or "old"...
    Yes, I'm printing over a network.
  4. #14
    Full Member
    Using
    AutoCAD 2011
    Join Date
    Oct 2010
    Posts
    35
    Default
    When I try to run the update it says:
    "The service pack could not be installed because the expected autodesk product could not be located on your computer. Make sure that you are using the correct service pack for the product.
  5. #15
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,090
    Default
    Service packs are available for both 32-bit and 64-bit systems. It is important that you download and install the correct version for your system.
  6. #16
    Full Member
    Using
    AutoCAD 2011
    Join Date
    Oct 2010
    Posts
    35
    Default
    Yes, but this is the message I got out the 32-bit version and I'm running Autocad 32-bit.
  7. #17
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,090
    Default
    The only other way I could see this message appearing is if you downloaded the update for 2010 instead of 2011 which seems unlikely.
  8. #18
    Full Member
    Using
    AutoCAD 2011
    Join Date
    Oct 2010
    Posts
    35
    Default
    ok... thanks for your help. I found out that if I close my properties pallette, the things I complained about with undo, plot etc. was suddenly close to normal. This is clearly not the right way to fix the problem but it's ok for now...
    Thanks to both of you... It was very helpfull...
Similar Threads
  1. att edit help
    By daveyboyd in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2010, 03:57 pm
  2. Cannot edit!!!
    By slowsilver! in forum AutoCAD Drawing Management & Output
    Last Post: 4th Feb 2010, 07:41 pm
  3. Edit DWF
    By Fire Alarm in forum AutoCAD General
    Last Post: 10th Nov 2009, 02:29 pm
  4. edit ground in view edit corridor sections
    By ikapo in forum Civil 3D & LDD
    Last Post: 10th Apr 2009, 10:24 am
  5. 3D Edit
    By Aravinthan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 7th Nov 2007, 11:16 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
