Viktorik Posted October 30, 2010 Share Posted October 30, 2010 Can anybody write how to make to see at quick properties the height and Z pozition of a 3d solid, I think my 3d solid is clasified at none, it was extruded,sliced... but there are no gemetry properties at options to choose Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 30, 2010 Share Posted October 30, 2010 To change your Quick Properties window when you have selected a 3D solid to view the Geometry properties click on the words No defined quick properties click to customize (in blue, lower left-hand corner) of the Quick Properties dialog box. This opens the Customize User Interface window. Look at the right pane. See the heading Geometry? Check off any or all of the six available properties. They are: Solid type, Height, Taper angle, Direction X, Direction Y and Direction Z. Click on the Apply button. Finally, click on the OK button to close the window. Your newly enabled properties should now appear in the Quick Properties window. Your 3D solid is classified as "none"? Can you post the drawing? Quote Link to comment Share on other sites More sharing options...
Viktorik Posted October 30, 2010 Author Share Posted October 30, 2010 http://yfrog.com/e995256767j it's a sliced box but for a box it shows height, sliced, the object become clasified at none, I think Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 30, 2010 Share Posted October 30, 2010 If AutoCAD does not recognize it as a solid then you did something incorrectly. Can you tell us how the original box was constructed to begin with? I'm on my laptop at the moment and I'm having a difficult time viewing the screenshot above especially the CUI. Quote Link to comment Share on other sites More sharing options...
Viktorik Posted October 31, 2010 Author Share Posted October 31, 2010 type ''box'' create a box, or extrude a closed polyline, after slice it and it become ''none'' Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 31, 2010 Share Posted October 31, 2010 I've sliced a number of solids over the past few years. I do not recall them changing properties on me. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 31, 2010 Share Posted October 31, 2010 type ''box'' create a box, or extrude a closed polyline, after slice it and it become ''none'' I tried this numerous times today and the result has always been the same. Doing a LIST on the objects remaining I get this: Command: LIST Select objects: 1 found Select objects: 3DSOLID Layer: "0" Space: Model space Handle = 1b6 History = Record Show History = No Bounding Box: Lower Bound X = 13636.5155, Y = 6314.6721, Z = 0.0000 Upper Bound X = 21036.0957, Y = 13405.5513, Z = 3810.5958 Quote Link to comment Share on other sites More sharing options...
Viktorik Posted November 5, 2010 Author Share Posted November 5, 2010 ok, thanks ... z= is what I need Quote Link to comment Share on other sites More sharing options...
