I think this is the same program as here, But they call it The CADDalog Maker 2000.
Its listed as freeware/shareware.
http://freecadapps.mcadcafe.com/swde...owcolor=ffffcc
Hello all...
years ago there was a program called The_Caddalog_Maker. It worked well with Ac14 etc.
anyone know of a similar program that will run with A2000+.
(it had the ability to make index sheets (8x11) of jillions of blocks.
thx
Steve
Thats kind of odd, When I go directly to the company that makes it, The site says no longer in business.
http://www.sectorpages.com/_rel/www.caddalog.com/245292
The first link is just a place to submit programs. It was dated 2005.
DropBox | finding the light...
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
And if one downloads "The_Caddalog_Maker_2000_V6_04_21.exe it won't install because somehow the exe file it tied to the net site which no longer exists. At least it won't install me, probably because it doesn't find AC2000 or AC2000i. It tries to modify something which doesn't exist in AC2008+. Oh, well, the joys of ACad updates ! !
<ugh> Steve
I tried to run the exe file as one would normally do, you can see all 200+ files in the winzip window, but for some reason they won't extract (that is, the directory which should contain the extracted files is always empty, I couldn't even extract one of the 200+ files) This is weird, because I'm not a noooobe with ACad, winzip. I doubt if Vista is screwing things up. I'll take the exe file over to another computer tomorrow morning for the heck of it. I guess one may be nuts for having more than a couple hundred blocks anyway.
Steve
Thats odd because I downloaded an exe file. I was not sure if I wanted to install this on my system, So I did not. After reading your posts further I see its dependant on the site being up and running, But they are no longer in business as I found out. I am not certain if it works or not.
Sorry
Hey guys... thanks for trying to help anyway...
cheers
Steve
Sorry, I meant what does the program do, what's its function?
