Results 1 to 6 of 6
Thread: plot to pdf
    Forum Newbie
    Architecture 2010
    Oct 2010
    1
    Default plot to pdf
    how can i plot my .dwg to pdf when under the plot/printing drop down there is no 'dwg to pdf' option? if used to be there before.
    thanks in advance.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    Do you know when or how the "DWG to PDF" option disappeared? Did you upgrade something?
    One option might be to get a new PDF plotter driver. I use "Cute PDF," which does a good job with larger plans, and it's free. You should also be able to get one from Adobe, which works fine for smaller drawings.
    breaking AutoCAD on a regular basis since 1991
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,374
    Quote Originally Posted by dena_r View Post
    thanks in advance.
    File, plotter manager, add a plotter wizard, use the my computer option, continue from there.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    Full Member drwhite's Avatar
    Mechanical 2010
    May 2009
    55
    Saw this http://cadtips.cadalyst.com/plotprint/plot-pdf-natively in Cadalyst today and this is great (as far as I am concerned). I searched and found the DWG to PDF.pc3 file and included in my plotters. I like the ability to turn layers off and on, in the PDF file.
    But I went to another station in the company and while we could plot with the .pc3, the pdf file that it created did not have the layers listed on the left like it was on my machine. Why? What is the setting to show the layers?
  5. #5
    Forum Newbie
    AutoCAD 2008
    Aug 2010
    7
    Quote Originally Posted by drwhite View Post
    in the plotter window.. Select Dwg to PDF.pc3.. then click on the properties button. Then click on Custom properties in the tree.. you'll see a button at the bottom of the window to open a new window.. in there at the bottom is the option to toggle saving layer info for PDF files..
  6. #6
    Mechanical 2010
    May 2009
    55
    Thank you!!
  1. Plot current layout without entering name is lisp plot string
    By hosannabizarre in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Apr 2011, 01:43 pm
  2. Replies: 1
    Last Post: 28th Sep 2010, 04:37 pm
  3. Plot problem (reverse plot)
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jul 2010, 12:11 pm
  4. Changes to plot layout and plot file for publish
    By GliderRider in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2009, 09:48 pm
  5. plot file locations for batch plot?
    By Kate M in forum AutoCAD General
    Last Post: 29th Oct 2003, 09:43 pm
Tags for this Thread
