AutoCAD Command Prompt when there is no drawings in Acad Editor.
muck
I am making a open command that controls autocads Default directory using VBA and Lisp.
My program will use open common dialog box to open a drawing with the last default dir
set by the previous saved drawing. No matter if Autocad is open by Ms Explorier or AutoCAD
open command. I use lisp to open my VBA open program at the command prompt. Maybe I
can change an AutoCAD menu macro to do the same thing?
Thank you,
On my system, the last directory used is the 'default' directory for the open dialog ... what am I missing? :?
mine also, when ever i use the open command it opens the last directory i was in that i opend a file in. are we not understanding what you want to accomplish?
Perhaps something like this will be useful:
(defun c:TEST (/ fileName)
 (vl-load-com)
 (cond (*acadApp*) ((setq *acadApp* (vlax-get-acad-object))))
 (if (setq fileName (getfiled "Select File" "[color=red]YourFilePathGoesHere[/color]" "dwg" )
   (vla-put-activedocument *acadApp*
     (vla-open (vla-get-documents *acadApp*) fileName :vlax-false)))
 (princ))
Note - Code will not function if SDI = 1.
Hope this helps!
