ziofel Posted November 4, 2010 Share Posted November 4, 2010 Is it possible to trim a block without exploding it? Also is it possible to explode a block and have it maintain its properties? Thanks Quote Link to comment Share on other sites More sharing options...
eyde Posted November 4, 2010 Share Posted November 4, 2010 Use clip command Quote Link to comment Share on other sites More sharing options...
ziofel Posted November 4, 2010 Author Share Posted November 4, 2010 Could you expand on that a bit please. Where do I find that one? I am using Autocad 2008. Quote Link to comment Share on other sites More sharing options...
eyde Posted November 4, 2010 Share Posted November 4, 2010 Just type in CLIP at command line and flollow instructions. You can also look in help if you need furture assistance. Happy clipping. Quote Link to comment Share on other sites More sharing options...
profcad Posted November 4, 2010 Share Posted November 4, 2010 There is another tool named CLIPIT. It on the Express Menu->Modify->Extended Clip. Quote Link to comment Share on other sites More sharing options...
ziofel Posted November 4, 2010 Author Share Posted November 4, 2010 Typing CLIPIT in command line asks to select object but will not let me select a block. Keeps saying invalid selection. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted November 4, 2010 Share Posted November 4, 2010 The Clip command wasn't introduced until 2010 Quote Link to comment Share on other sites More sharing options...
eyde Posted November 4, 2010 Share Posted November 4, 2010 Under Using shows 2010, but later After I answerd came back and said he/she was using 2008. Quote Link to comment Share on other sites More sharing options...
ziofel Posted November 4, 2010 Author Share Posted November 4, 2010 Nevermind I will use the superhatch command. I have to add a couple of lines to close boundary but works faster than copying the block over and over. Quote Link to comment Share on other sites More sharing options...
profcad Posted November 4, 2010 Share Posted November 4, 2010 (edited) When using CLIPIT, you have to select the cliping object first, then the block. It works fine on 2005, so it should work in 2008. Command: CLIPIT Pick a POLYLINE, CIRCLE, ARC, ELLIPSE, or TEXT object for clipping edge... Pick an IMAGE, a WIPEOUT, or an XREF/BLOCK to clip.. Edited November 4, 2010 by profcad typo Quote Link to comment Share on other sites More sharing options...
ziofel Posted November 5, 2010 Author Share Posted November 5, 2010 Will this not work with a line? Does it have to be a POLYLINE, CIRCLE, ARC, ELLIPSE, or TEXT object for clipping edge? Quote Link to comment Share on other sites More sharing options...
profcad Posted November 5, 2010 Share Posted November 5, 2010 It will not work with a line. Draw a closed polyline around the part you want keep. Then run the command. Quote Link to comment Share on other sites More sharing options...
ziofel Posted November 5, 2010 Author Share Posted November 5, 2010 Thanks. extra work but a lot less than exploding and worrying about it that way. Quote Link to comment Share on other sites More sharing options...
rkent Posted November 5, 2010 Share Posted November 5, 2010 XCLIP should work, I think CLIP is just an alias for XCLIP added in 2010. Quote Link to comment Share on other sites More sharing options...
ziofel Posted November 5, 2010 Author Share Posted November 5, 2010 Ok, how do you use XCLIP? I can' t seem to make it work. Basically trying to CLIP insulation inside stud wall. _______________ |XXXXXXXXXXXX|XX X = insulation _ = wall boundary as a line Crude but should point out what I need to do. CLIP insulation at second | mark. That way it ends up like this. _______________ |XXXXXXXXXXXX| Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted November 5, 2010 Share Posted November 5, 2010 Maybe you would be better off with a routine for drawing insulation. Do a search on the web for batt.lsp, or insulation +lisp Quote Link to comment Share on other sites More sharing options...
qball Posted November 10, 2010 Share Posted November 10, 2010 dynamic blocks with array and stretch work for Batting as well. For me anyway, some might require more flexibility with scales, etc. Quote Link to comment Share on other sites More sharing options...
