tajanat Posted November 5, 2010 Share Posted November 5, 2010 Hi, everybody! I am drawing my plans in AutoCAD 2006. After finishing one plan, I open it in Adobe Illustrator CS3. Before opening in Adobe Illustrator, I flatten all splines to polylines. Also I don`t have single arcs but polylines consisted of lines and arcs. But in Illustrator this arcs from polylines are not smooth. Arc becomes fractured in few segments whit corners. I notticed that spline converted to polyline looks much better. So I tried to convert arc to spline: I pedited arc to polyline. Then I converted this polyline to spline ( http://www.ehow.com/how_6529003_autocad-convert-2d-polyline-spline.html ) and after that flattened spline back to polyline. But in Illustrator it looked almost the same as previous arc. I also try to draw arc whit spline. I used both dots and tangents to get a perfect spline, but it also did not look much better in Illustrator. So I am interested if anyone knows how to draw an arc in AutoCAD so that it looks smoother in Illustrator? I know about the option "Object-> Path-> Simplify" in Illustrator and it smoothens my arc a lot, but I woud like to have a perfect arc from AutoCAD because I don`t have time to go from one arc to another in Illustrator and Simplify it... I also tried to achieve that over a PDF file. I transferred PDF, created in Autocad using PDF Page maker plugin, into Illustrator. And arc looked tottaly smooth. But I lost my layers. I didn`t find out how to open an Autocad generated layered PDF in Illustrator and retain the PDF`s layer structure. I converted my AutoCAD file to layered PDF. But in Adobe Illustrator, all layers became merged in one layer. I heard that PDF layers are conceptually very different than Illustrator layers. But still I wonder if there is plugin that could read PDF layers in Illustrator? Opening AutoCAD file in Illustrator brought me also problem with Mtext. Every Mtext splits in single-lined text, so I can not adjust paragraphs. I found script for Adobe Illustrator called "join text frames" http://vectips.com/tricks/10-free-an...rator-scripts/ It binds broken text frames perfectly. But it means that I have to jump from one group of text to another and repeat this action as many times as many groups of text I have. And sometimes it lasts to long. So I would rather to open mtext proper in Illustrator. Does anyone know how to modify settings in AutoCAD to keep Mtext during opening in Illustrator? I wonder if this problem disappears with newer versions of Adobe Illustrator - CS4 and CS5!? Thank you all in advance! Quote Link to comment Share on other sites More sharing options...
