Tracing
Big G
Hi
What is most efficient method of tracing over an existing drawing, ie make original drawing show a negative appearance, draw over then remove/hide original.
Electronically trace it using a digitizing tablet.
Thanks again Mark, once again I have to show my ignorance and admit I have no Knowledge whatsover on digitizers.
just scan the drawing make a jpg then insert image rescale as best as possible and away you go, use ortho a bit to make lines sq if you want exact measurements maybe use snap set to a resonable tolerance with the drawing scaled up or always use dynamic input so line length is correct
