Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Full Member
    AutoCAD 2011
    Nov 2010
    35
    Default Can someone please help me to find the upper menus in autocad 2011
    I lost the upper commands in AutoCad 2011 and need help to bring them back
    thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Try typing MENU at the command line. Select the acad.cuix.
    Full Member
    AutoCAD 2011
    Nov 2010
    35
    thanks for the quick reply, i tried that and it gave me unknown comand
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    OK. Just so I know we are talking about the same thing...
    Are you referring to the Menu Bar with the pull-down menus (File, Edit, View, Insert, etc., etc.)?
  5. #5
    Full Member
    AutoCAD 2011
    Nov 2010
    35
    Yes with all the upper manus and icons: layers, dim, etc.
    i basiclly have almost no manus and icon just empty large screen (working area)
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    It always help us if we have ALL the information beforehand so we know the scope of the problem we're dealing with. More info = better help.
    So now you're saying that the Ribbon is missing too?
    The Ribbon consists of Tabs and each tab has a series of Panels on them. Example: the Home tab has the Draw, Modify, Layers, Annotation, Block, Properties, Utility and Clipboard panels on it. This is what you are referring to isn't it?
    Had you just opened up AutoCAD or had you been working in AutoCAD when you lost everything?
  7. #7
    Full Member
    AutoCAD 2011
    Nov 2010
    35
    Yes it's true the Ribbon is all missing i only have the icons for new open save print and search on the right side
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Were you working in AutoCAD when this happened or had you just opened it up for the start of a new drawing session?
    It sounds like you still have the Quick Access Toolbar available.
    You have a command line at the bottom of your screen right?
  9. #9
    Full Member
    AutoCAD 2011
    Nov 2010
    35
    it's happened while i was working in AutoCAD
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Look in the lower right-hand corner of your screen. There should be a button with a very small screen icon on it. If you hover above it a Tooltip will appear called Clear Screen. Click on that button. What happens? Any change to your screen? If so, what changed?
  1. Replies: 0
    Last Post: 29th Sep 2010, 12:10 am
  2. AutoCAD 2011 and AutoCAD LT 2011 Update 1 Available for Download
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 24th Aug 2010, 09:20 pm
  3. AutoCAD 2011 and many other Autodesk 2011 Products Released.
    Last Post: 25th Mar 2010, 02:46 pm
  4. Upper and lower case lettering
    By Coosbaylumber in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Apr 2009, 05:35 pm
  5. Autocad Menus
    By fathead in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2007, 05:07 am
