tools "not found"
jbrm
for example when i click on "Door - Imperial"
i get the message
"Source drawing "C:\Program Files\AutoCAD 2010\Sample\Dynamic
Blocks\Architectural - Imperial.dwg" for block "Door - Imperial" not found."
what do i need to do to fix this???
Sample dynamic blocks are not downloads. Normally they would be loaded as part of the installation process unless you decided on a "custom" installation and neglected to indicate that you wanted them.
You can try to fix the problem by running the REPAIR option from the Windows Add/Remove Programs feature just have your installation DVD on hand as you will probably be asked to insert it in the DVD drive at some point.
