Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2011
    Sep 2010
    2
    Default dynamic blocks and reverse rotation actions
    I am working on a block where I need to illustrate counter-rotating objects... does anyone have an idea on how to apply an independant basepoint rotation action that would allow a clockwise rotation?
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Can you post the drawing?
    Do you mean that if you rotate one object clockwise, another object rotates counter- clockwise at the same time?
    Forum Newbie
    AutoCAD 2012
    Dec 2012
    1
    Thats exactmy what I am looking to do. A rotation parameter that rotates sth exactly the same angle as another rotation parameter but in another direction or one parameter that has two acitons one with a negative angle modifier (such a modifier doesnt exist). In other words how to relate values of two rotation parameters... Any ideas for two counter-rotating objects with one grip?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    You might try using angular constraints.
  1. Dynamic Blocks - Circles and Lookup Parameter / Actions
    By TheyCallMeJohn in forum AutoCAD General
    Last Post: 25th Oct 2010, 06:09 pm
  2. Dynamic blocks and chained actions
    By stevo99 in forum AutoCAD Drawing Management & Output
    Last Post: 15th Aug 2010, 09:11 pm
  3. chaining stretch actions in dynamic blocks
    By Tim Papworth in forum AutoCAD General
    Last Post: 5th Dec 2008, 11:43 am
  4. Chained Actions in Dynamic Blocks
    By Locki in forum AutoCAD General
    Last Post: 15th Aug 2008, 08:10 pm
  5. rotation parameter (dynamic blocks)
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 27th Feb 2008, 08:42 am
Tags for this Thread
