Son of Aslan Posted November 16, 2010 Share Posted November 16, 2010 15 years ago, I worked at a furniture company that ran their repair department with a AutoCAD R12 computer with lisp routines for converting geometry into G-Code that was recognizable by Gerber cutting machines. They also had lisp routines that would work the other way around, in that they would convert G-Code text files BACK into geometry, while also showing tool paths and the like. These particular routines were seldom needed or used. The reason I mention this is to show that I know such a thing exists, for I have used it in the past. Does anyone know where I could find a autolisp routine that would convert modern G-Code back into AutoCAD as geometry? I have looked online, and I cannot find anything lisp oriented. I found a few installable programs, but I would rather do it with a lisp routine right in AutoCAD. Such a routine would come in handy where I work and in checking G-Code files before actually running them, to ensure it cuts correctly. The G-Code I wish to convert was programmed for a Komo Router VR 510 that cuts 4' x 8' boards with a wood bit and drills. A sample of the code I wish to convert into geometry is... % :(3159-STLD 5/8 OSB) N1G00G17G20G28G40G80G91Z0M5 N2G90 N3M08 N4G52X0Y0Z0 N5G08P1 N6(DRILL .34375 DIA.) N7G28G91Z0M05 N8G90T2006M06 N9T102 N10G00G17G55X12.397Y41.4811M03S6500 N11G00G43H6Z1.6 N12G01Z-.06F400. N13G00Z1.6 N14G00X17.2965Y14.1266 N15G01Z-.06F400. N16G00Z1.6 N17G00Y16.6266 N18G01Z-.06F400. N19G00Z1.6 N20G00Y32.7377 N21G01Z-.06F400. N22G00Z1.6 N23G00Y35.2377 N24G01Z-.06F400. N25G00Z1.6 N26G00X30.897Y41.4811 N27G01Z-.06F400. N28G00Z1.6 N29G00X33.4083 N30G01Z-.06F400. N31G00Z1.6 N32G00X51.9083 N33G01Z-.06F400. N34G00Z1.6 N35G00X55.2499 N36G01Z-.06F400. N37G00Z1.6 N38G00X73.7499 N39G01Z-.06F400. N40G00Z1.6 N41G00X76.2611 N42G01Z-.06F400. N43G00Z1.6 N44G00X94.7611 N45G01Z-.06F400. N46G00Z1.6 N47G00X85.9215Y35.2377 N48G01Z-.06F400. N49G00Z1.6 N50G00Y32.7377 N51G01Z-.06F400. N52G00Z1.6 N53G00Y16.6266 N54G01Z-.06F400. N55G00Z1.6 N56G00Y14.1266 N57G01Z-.06F400. N58G00Z1.6 N59(DRILL .5 DIA.) N60G28G91Z0M05 N61G90T2009M06 N62T102 N63G00G17G55X80.6091Y3.8266M03S6000 N64G00G43H9Z2. N65Z1.6 N66G01Z-.04F500. N67G00Z2. N68G00Y14.4516 N69Z1.6 N70G01Z-.04F500. N71G00Z2. N72G00X62.6091 N73Z1.6 N74G01Z-.04F500. N75G00Z2. N76G00Y3.8266 N77Z1.6 N78G01Z-.04F500. N79G00Z2. N80G00X40.6091 N81Z1.6 N82G01Z-.04F500. N83G00Z2. N84G00Y14.4516 N85Z1.6 N86G01Z-.04F500. N87G00Z2. N88G00X22.6091 N89Z1.6 N90G01Z-.04F500. N91G00Z2. N92G00Y3.8266 N93Z1.6 N94G01Z-.04F500. N95G00Z2. N96G00Y22.4377 N97Z1.6 N98G01Z-.04F500. N99G00Z2. N100G00Y33.0627 N101Z1.6 N102G01Z-.04F500. N103G00Z2. N104G00X40.6091 N105Z1.6 N106G01Z-.04F500. N107G00Z2. N108G00Y22.4377 N109Z1.6 N110G01Z-.04F500. N111G00Z2. N112G00X62.6091 N113Z1.6 N114G01Z-.04F500. N115G00Z2. N116G00Y33.0627 N117Z1.6 N118G01Z-.04F500. N119G00Z2. N120G00X80.6091 N121Z1.6 N122G01Z-.04F500. N123G00Z2. N124G00Y22.4377 N125Z1.6 N126G01Z-.04F500. N127G00Z2. N128(ROUTER-BIT .5 DIA.) N129G28G91Z0M05 N130G90T2001M06 N131T102 N132G00G17G55X78.0006Y18.3759M03S21000 N133G00G43H1Z2. N134Z1.6 N135G41D01G01X78.2756F450. N136X81.4856Y18.3758Z-.005 N137X94.0602Y18.3755F900. N138G02X94.7532Y17.6286I-.056J-.7469 N139G01Y15.3484 N140G02X94.9823Y15.0036I-.1448J-.3448 N141G01Y4.5015 N142G02X90.7114Y-.2234I-4.749 N143G01X12.5282 N144G02X8.2358Y4.5036I.4566J4.727 N145G01Y15.0036 N146G02X8.4858Y15.3564I.374 N147G01Y17.6286 N148G02X9.2348Y18.3776I.749 N149G01X81.4856Y18.3758 N150X81.9856F900. N151X85.1956Y18.3757Z1.6 N152G00Z2. N153G40G00X85.4706 N154X78.0006Y36.987 N155Z1.6 N156G41D01G01X78.2756F450. N157X81.4856Y36.9869Z-.005 N158X94.0602Y36.9866F900. N159G02X94.7532Y36.2397I-.056J-.7469 N160G01Y33.9595 N161G02X94.9823Y33.6147I-.1448J-.3448 N162G01Y23.1126 N163G02X90.7114Y18.3877I-4.749 N164G01X12.5282 N165G02X8.2358Y23.1147I.4566J4.727 N166G01Y33.6147 N167G02X8.4858Y33.9675I.374 N168G01Y36.2397 N169G02X9.2348Y36.9887I.749 N170G01X81.4856Y36.9869 N171X81.9856F900. N172X85.1956Y36.9868Z1.6 N173G00Z2. N174G40G00X85.4706 N175X75.0746Y43.268 N176Z1.6 N177G41D01G01Y43.543F450. N178Y46.753Z-.005 N179Y47.8551F900. N180X95.9476 N181Y36.9821 N182X75.0746 N183Y46.753 N184Y47.253F900. N185Y47.8551Z.296 N186X77.6826Z1.6 N187G00Z2. N188G40G00X77.9576 N189X54.0634Y43.268 N190Z1.6 N191G41D01G01Y43.543F450. N192Y46.753Z-.005 N193Y47.8551F900. N194X74.9364 N195Y36.9821 N196X54.0634 N197Y46.753 N198Y47.253F900. N199Y47.8551Z.296 N200X56.6713Z1.6 N201G00Z2. N202G40G00X56.9463 N203X32.2218Y43.268 N204Z1.6 N205G41D01G01Y43.543F450. N206Y46.753Z-.005 N207Y47.8551F900. N208X53.0948 N209Y36.9821 N210X32.2218 N211Y46.753 N212Y47.253F900. N213Y47.8551Z.296 N214X34.8297Z1.6 N215G00Z2. N216G40G00X35.1047 N217X11.2105Y43.268 N218Z1.6 N219G41D01G01Y43.543F450. N220Y46.753Z-.005 N221Y47.8551F900. N222X32.0835 N223Y36.9821 N224X11.2105 N225Y46.753 N226Y47.253F900. N227Y47.8551Z.296 N228X13.8185Z1.6 N229G00Z2. N230G40G00X14.0935 N231G28G91Z0M5 N232G28G91X0 N233M09 N234G90 N235G52X0Y0Z0 N236G08P0 N237M30 % Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 16, 2010 Share Posted November 16, 2010 (edited) I suppose you already stumbled across this in your search? http://www.timeguy.com/cradek/autocad Only other thing I can think of is to check the CNC Zone website for an open source G-code CAD/CAM program. Good luck. Edited November 16, 2010 by ReMark Quote Link to comment Share on other sites More sharing options...
