Results 1 to 6 of 6
    Full Member
    therealsaint01's Computer Details
    mac osx 10.7.4
    Apple imac 27"
    i7
    2.8ghz quadcore
    8gb
    ATI radeon 4850 512mb
    1 TB
    built in 27" and 24" samsung led
    See details...
    therealsaint01's Discipline Details
    underpaid draftsman
    See details below.
    Im mainly Architectural but i want to move into mechanical. I enjoy Motor parts and will create my invention sometime
    AutoCAD 2012
    Jan 2010
    South Africa
    40
    Default Plotting points from excel to Autocad
    Hi Guys
    I need to put 171, x and y co-ords to make a bunch of points..the co-ords are in excel.. Is it possible to "copy paste" from excel to Autocad and the points will all be there-correctly?
    It just becomes a mission to punch them in manually.
    Thanks
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by therealsaint01 View Post
    Hi Guys
    Easy to do with a script file.
    1. Open the Excel file.
    2. Save it as a .CSV file (comma separated values).
    3. Open the .CSV file in notepad, add two lines at the top:
    ._multiple
    ._point
    4. Then save this file with a .SCR file extension.
    5. In AutoCAD run the ._Script command, and pick the .SCR file above.
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    If you have in Excel the X in column A and the Y in B, enter in C1 =Concatenate(a1,",",B1) and drag down across 170 lines. You should get x,y in column C. Select the column and copy it (ctrl+C). In AutoCAD enter in the command line multiple point<enter>, click in the command line and paste (ctrl+V).
    But turn off the running osnap before that.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  5. #5
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Hey Rkmcswain & fuccaro thats a couple of neat tricks, adding on if you want a line joining a sequence of points together then just
    "Select the column and copy it (ctrl+C). In AutoCAD enter in the command Line <enter>, click in the command line and paste (ctrl+V)."
    Repeat for group of points as required. Could probably work for other commands also.
    Dont forget insert block etc its very easy to write a script in excell adding the relevant commands as a column insert blockname x,y
  6. #6
    AutoCAD 2006
    Nov 2002
    3,540
    ... and if you try to draw lines, you don't even need to enter REPEAT because AutoCAD will repeatedly ask for a new point until you terminate the command. The same goes for polylines.
    many years ago I used to use Excel to generate my scripts.
  1. plotting - imported excel files to AutoCAD
    By SJGREY in forum AutoCAD General
    Last Post: 28th Sep 2011, 05:57 pm
  2. AutoCAD drawling to excel data points
    By West87 in forum AutoCAD General
    Last Post: 27th Mar 2008, 05:51 pm
  3. Points from Excel
    By Primal Scientist in forum AutoCAD General
    Last Post: 9th Oct 2007, 04:13 pm
  4. how do i get the points from excel/db onto the layers?
    By Fredy75 in forum AutoCAD Beginners' Area
    Last Post: 18th Oct 2005, 12:28 am
  5. Creating Points using EXCEL
    By Geo in forum AutoCAD General
    Last Post: 30th Jun 2005, 08:15 pm
