My boss needs one profile view with two profiles that meet at a point. The first profile starts at station 0 and ends at station x, then the second profile starts at station x and ends at station z. z is obviously greater than x.
Both profiles are on the same alignment. They overlap at station x, more or less. There is no problem with creating either profile or the profile view. The only problem is restricting the start point or end point for a profile in the view. Is this possible, or are there only workarounds that get progressively more tedious? For instance, the simplest way I could think of to make it work was to create borders for both surfaces and adjust them incrementally until the gap got fairly close.
