Make Tapered Offset
I'm looking for a way to produce a tapered offset in AutoCad 2008 (a simple linear taper will do for a starter), perhaps by specifying starting and ending offset distances to be applied along the length of a selected arc, polyline (2D) or spline.
I'm thinking that this will probably require some code, although it seems like this might be a fairly common requirement, such that there would be an existing solution that I just haven't gleaned as yet.
Thoughts?
Do you have any experience writing lisp routines?
No, been able to avoid the pain so far but guess I may have to start.
My favorite language was Borland Pascal (back in the day) and I've played with Forth a little bit (probably closer to Lisp) but found it weird doing everything on the stack, kind of like programming in reverse polish. :]
